HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree193Likes
Old 08-20-2013, 06:43 PM
  #4051
Trader Rating: 21 (100%+)
i use to run the spec nano techs too until i borrowed a SMC battery. SMC has a race formula 6500mah 70c battery that works really good on the high amp HW ESC's. I can run a 8 min main np on there batteries and have plenty of power to the end of the race. For a battery under $50 its well worth it.
NvDesertRat96 is offline
Old 08-20-2013, 06:45 PM
  #4052
fq06's Avatar
SMC over Hobbyking all day long. Better quality and support along with comparable pricing.
fq06 is offline
Old 08-21-2013, 01:08 AM
  #4053
Trader Rating: 58 (100%+)
Originally Posted by redtags
I'm running 2x 2s nanotech 6600 mah on my 150a xerun. Recently 1 of it gave up. I plan to buy a new a spec nanotech but biggest capacity is only 6200 mah with same 65-130c rate.
So it will be 6600 and 6200 mah with same discharge rate. Is it ok to run with different batt cap like that, other than faster volt drain on smaller cap lipo ? I plan to change to all a spec once my old batt died.
NO or you will kill your new battery. The batteries need to be the same amperage or as soon as you plug them in the 6600 will try to balance out with the 6200 and the 6200 can become over charged and damaged or ruined even though it's not a huge difference between the two. If you don't ruin the 6200 right away it will more than likely have a very short lifespan.
Hobbyking still makes the 6600 nano-tech, it's just not the new a-spec line. So I guess choose what battery you want to run and get them in sets of 2.
Prostreet314 is offline
Old 08-21-2013, 08:58 AM
  #4054
Thanks a lot for the response and explanation man. I really appreciate it.
Glad I ask here first, otherwise I will ruin my new batt immediately.
redtags is offline
Old 08-21-2013, 09:27 AM
  #4055
snwchris's Avatar
Just curious if I can use a HW150A ESC in a 4x4 SC on 2s??
I have one as a backup and was looking to hook it up and try out.
snwchris is offline
Old 08-21-2013, 09:44 AM
  #4056
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
I'd strongly recommend against it. The bec in the xerun 150 hates 2s packs and will glitch really badly. It really was designed for 3s-6s. I tried running one in an scte last year and it just didn't like it.
Rockthecatbox21 is offline
Old 08-21-2013, 09:50 AM
  #4057
snwchris's Avatar
OK, thanks for the heads up...
I was just looking to get by until I can order a new SCTPro next week.
snwchris is offline
Old 08-21-2013, 01:04 PM
  #4058
babydaddy's Avatar
You sure can run it on 2s. Just run an external BEC and it will be glitch free. I see people do it all the time. Castle makes an external BEC for about 20 dollars
babydaddy is offline
Old 08-21-2013, 02:36 PM
  #4059
Slotmachine's Avatar
Hobby Wing makes one also..............
Slotmachine is offline
Old 08-21-2013, 06:12 PM
  #4060
rcboy1's Avatar
rcboy1 is offline
Old 08-21-2013, 08:53 PM
  #4061
Unless it is one I have not seen, the HW blows compared to the Castle one. Lower amp output and you can not adjust the voltage to a nice 7v or more like you can with the Castle.
kcobra is offline
Old 08-21-2013, 08:57 PM
  #4062
You are correct that the 6200 will most likely be over discharged, assuming he is running them in series (most likely). You are wrong on the "balancing" comment though. The only way the two packs would try to "balance" themselves together is if he was running them in parallel. If that was the case then they would be fine to run together.
kcobra is offline
Old 08-21-2013, 08:59 PM
  #4063
slight issue with SC8 ESC tonight i went through two fans any ideas what could possible cause this
Boostedss is offline
Old 08-23-2013, 12:37 AM
  #4064
Hi, I'm having a problem with my ESC, it burnt one motor last weekend and I'm afraid of repeating the disaster this weekend if I continue using the ESC...
The problem is that when the motor is not attached to the transmission all works fine, but when I attach it to the car and throttling, the motor seems to be cogging, and the car can finally go forward but the speed is very low and the motor gets very hot extremely quick, so I must stop the car. If I block the slipper clutch by hand it produces the same effect, the motor gets very hot and if I hit full throttle the ESC fan becomes OFF and when I release the trigger it starts to spinning again.
I'm using a Xerun v2.1 120A with a LRP X12 13.5T with sensor cable, STOCK firmware and 0 timming/turbo.
Regards.
BeLiPoWa is offline
Old 08-23-2013, 01:44 AM
  #4065
lewis110's Avatar
Regards.
So if I'm understanding correctly the motors fine out of the car. Doesn't heat up, but as soon as its installed it doesn't work? Do the car move freely? No bad bearings causing a bind anywhere? Also make sure your mounting screws aren't to long and causing a short inside the motor itself. Was this a new motor combo? Or is it something new that just started happening.
lewis110 is offline
