HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 08-05-2013, 05:43 AM
  #3886
Trader Rating: 33 (100%+)
Originally Posted by RokleM
Most HW ESC's I've seen only support 3A output. Running Savox, a lot of people recommend 5-6A, so it could have indeed been the issue. I would like to see HW increase that number on newer models (as well as adjustable or higher voltage BEC).
Originally Posted by Slotmachine
6.0 volts 3 amp on the sct pro 120 amp model.
That's what I said too, so not sure why you quoted my post and stated the same thing? Or did you not notice the "A" (amps) perhaps? Amps != Volts
RokleM is offline
Old 08-05-2013, 06:20 AM
  #3887
Originally Posted by hobdog
What is the recommended esc for 2wd mod buggy? I am running a 8.5 and currently run a Tekin rs. Also, what is the correct program box for it? Thanks
The V3 or V3.1.i run the V3 in my buggy with an 8.5 and love it.
tripleh is offline
Old 08-05-2013, 06:21 AM
  #3888
Trader Rating: 19 (100%+)
The xerun 80 is rated to handle up to 2400 kv. So i pulled the trigger on the HPI/CC 40x72mm 2350kv. It should be fast as he'll.
malik is offline
Old 08-05-2013, 08:58 PM
  #3889
Trader Rating: 21 (100%+)
Went and did some testing a the track today. I changed the pinion to a 12t, set LVC to 3.2v, re-calibrated the throttle range settings and left timing at 0 and punch at 1. I ran my 2s 5300mah 50c-100c lipo till it hit LVC (the ESC was flashing red not green) which was about 20mins of run time. It never cut out once when running, when i checked temps motor 130 and ESC was 90-120 depending where i pointed the temp gun. Im gonna race again Wednesday and ill see how it goes. Which im still a little aprehensive that my problem is solved. I so wanted this Xerun System to just be a ass kicking winning machine. I may have to look for a Xerun 3656-4000kv
Thanks for everyones help
NvDesertRat96 is offline
Old 08-05-2013, 09:01 PM
  #3890
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
sounds like you got it figured out. with those temps, after 20 mins, you should be able to gear up at least 1, if not 2 teeth for race conditions. i would still lower LVC to 3.0.
RC*PHREAK is offline
Old 08-05-2013, 09:14 PM
  #3891
rcboy1's Avatar
I agree, looks like its all good now. it you are looking for more performance you can either go up on timing or teeth on the pinion. depends what you want from the system.
Just keep the esc and motor at happy temperatures and they should last you for a long, long time.
rcboy1 is offline
Old 08-05-2013, 09:31 PM
  #3892
I think im just gonna run it as is for race day. If its preforming good through the heats ill start with going up in timing and/or punch. I dont have many options for spurs MIP makes a 41t and thats the biggest i could find. A 13t pinion is very possible but just want to run it first. Ill keep you all updated.
Old 08-05-2013, 10:16 PM
  #3893
Rockthecatbox21's Avatar
I'm gonna take a guess and say it's ok to turn off lvc under certain conditions. Those being i never race more than 8 mins and i always use the timer on my radio during practice (never go more than 6-7 mins at most). I feel like if you check your packs before you run and only drive conservative amounts of time, it'll be ok right?
Rockthecatbox21 is offline
Old 08-05-2013, 10:23 PM
  #3894
doyschultz's Avatar
I have a question regarding the V3 stock firmware. Is this essentially "blinky" mode? If not is there a specific firmware I need install to meet the "blinky" mode criteria for my local track?
I'm running an xerun 120A 2.1 speedo.
doyschultz is offline
Old 08-05-2013, 10:25 PM
  #3895
i dont have a cool controller like that lol. But i think ill pass on the no LCV idea. I cant afford to be buying lipo packs if one were to pop due to going past that danger point. Its a safety feature for a reason. Im to noob to not use the LVC.
Old 08-05-2013, 11:34 PM
  #3896
RC*PHREAK's Avatar
yes. when you feel a NOTICEABLE drop off in punch/speed, it's time to take the truck off. this is usually in the 3.0 to 3.2v per cell range, but could be triggered earlier by the esc.
Old 08-06-2013, 02:53 AM
  #3897
lewis110's Avatar
If your asking about the 120A V2.1 then you need to use the 508_No_Timing firmware to get into blinky mode.
If your asking about the V3 series you can do anything you want with that without updating firmware. Blinky is profile 2, it will also blink when you set boost/turbo to 0 in any profile. All you do is hook your LCD program box up.
lewis110 is offline
Old 08-06-2013, 05:41 AM
  #3898
Technically once you get to that point of noticable decrease, you have gone too far.
Personally I know my packs and dislike the LVC on the HW. I've had them shutoff at nearly 4v per cell so I just turned it off. Also, I can just monitor the volts on my TX via telemetry.
RokleM is offline
Old 08-06-2013, 06:07 AM
  #3899
doyschultz's Avatar
I noticed most of the recent firmware is labeled as V3 thats why I was asking about V3. Can V3 firmware be ran in 2.1 speedo?
Ill use the firmware noted to run blinky mode. In my second car im running the same speedo (120A 2.1) but this car will be ran in a mod class. What is the latest and greatest firmware to run in this car?
Old 08-06-2013, 06:23 AM
  #3900
Pulse_'s Avatar
is there any chance HW will release a compact esc for 6s application in 1/8? let's say a 120a?
Pulse_ is offline
