HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 08-04-2013, 11:03 AM
  #3871
Trader Rating: 19 (100%+)
Hey i have a Xerun 80amp 8th scale esc, im using a CCBEC for my servo and running on 4s i want to know can i run a castle 40x72mm 2350kv motor without killing the esc? I dont do no crazy stuff dirt only no asphalt racetrack usually.
malik is offline
Old 08-04-2013, 11:13 AM
  #3872
rcboy1's Avatar
A 150amp would be the better choice, but if you gear it a little bit low and watch the temps it should be fine.
rcboy1 is offline
Old 08-04-2013, 11:14 AM
  #3873
Rockthecatbox21's Avatar
Originally Posted by rcboy1
That is really weird. were you using a bec?
and actually i have no idea as ive never had a hw esc go up, believe it or not.
and other equipment you use on it? try gearing down first and see what happens.
Just as paul said the v3 is a great reliable esc for this.
No external bec as i was told about how "the hobbywing bec can handle anything". I'm really thinking it was my long motor wires and savox servo that killed it. I'm still gonna run the same savox servo, but i will be shortening my motor wires this time.
Rockthecatbox21 is offline
Old 08-04-2013, 11:24 AM
  #3874
rcboy1's Avatar
It can, thats why i was wondering. a bec isnt necessary and it can blow up escs. The savox mightve done it, or it couldve just been simply bad luck. you could try soldering on an additional capacitor to the battery leads just to try to smooth out the power input.
rcboy1 is offline
Old 08-04-2013, 01:15 PM
  #3875
Trader Rating: 33 (100%+)
Most HW ESC's I've seen only support 3A output. Running Savox, a lot of people recommend 5-6A, so it could have indeed been the issue. I would like to see HW increase that number on newer models (as well as adjustable or higher voltage BEC).
RokleM is offline
Old 08-04-2013, 01:57 PM
  #3876
Im running an Ace 2000kv 4074 now, i just wan more speed out of it
malik is offline
Old 08-04-2013, 02:16 PM
  #3877
COBRARACING's Avatar
Originally Posted by NvDesertRat96
I had my timing at 0 and punch at 1. The ESC fan was working. My truck is fairly new and only has about 8 race days on it. Everything rolls smooths no indication of a bad bearing. Gear mesh is good. Im stumped and frustrated
You could also have an issue with the motor drawing way to much current for some reason .if there any visible damage to the capacitors like leaking or puffed?
COBRARACING is offline
Old 08-04-2013, 02:20 PM
  #3878
In my case with my old mmp, an external bec solved pretty much all the issues i was having. My esc caps were the first thing to show damage. They were leaking dark fluid.
Yes, i really think the savox drew a little too much power than the internal bec could handle. If the esc can't handle any servo, then don't advertise it.
Old 08-04-2013, 04:24 PM
  #3879
Trader Rating: 21 (100%+)
Not that i see, i also run 2 additional caps that are plugged into my receiver. I didnt have the over heat problems while using the stock Losi set up. I wanted more torque and speed thats why i got the Xerun. I also had great luck with my EZrun set up in my Mod 2wd SCT, thats why i got the Xerun for my SCTE 4x4. I have yet to try a 12t pinion, it just sucks i have to gear so darn low just to keep cool. Alot of races are won on the straight at my track so having ridiculous amount of speed sometimes is the difference between a win and 2nd. We also have a couple jumps that you need to go from a 180 turn to a up hill jump so the off the line torque is needed too.
I was hoping someone with a Losi SCTE 4x4 that has the Xerun SCT Pro and 4700kv combo would chime in maybe that had the same issue.
I checked all my bearings. They were all fine. My center diff was due for a rebuild (which i did) so really only thing to do is try a 12t pinion. Ill go to the track Monday and try one and see if i still over heat. If i do ill be calling customer service at HW.
NvDesertRat96 is offline
Old 08-04-2013, 05:00 PM
  #3880
Slotmachine's Avatar
6.0 volts 3 amp on the sct pro 120 amp model.
Slotmachine is offline
Old 08-04-2013, 06:01 PM
  #3881
As long as an external BEC is hooked up right it will not blow up ESC's. If anything it causes less strain on ESC's.
kcobra is offline
Old 08-04-2013, 06:35 PM
  #3882
rcboy1's Avatar
In my experience the mmp has an even worse bec than the older HW models, which is why a bec is almost needed. I do agree, the BECs in not only HW but lots of others should really be able to handle higher loads. that said, the majority of the time someone is having brown out issues or the like a savox servo is usually the issue unfortunately. if they didnt pull as much current they would be the perfect servos.
IF it is hooked up correctly. We all make mistakes sometimes and even if a bec is installed correctly the first time, if you have to do soldering for some reason you may hook it up wrong while rushing. Or you may have a defective bec. to me an external BEC is just another thing that can and will go wrong.
rcboy1 is offline
Old 08-04-2013, 07:21 PM
  #3883
Sure. People can also hook up batteries backwards, etc. An external BEC solves far more problems than it introduces. No brownouts, no missed laps because of low voltage, faster servos, etc.
kcobra is offline
Old 08-04-2013, 07:24 PM
  #3884
rcboy1's Avatar
Youve got a point. still though, i thought i would ask to see if he had one on to better know his situation.
rcboy1 is offline
Old 08-04-2013, 07:42 PM
  #3885
hobdog's Avatar
What is the recommended esc for 2wd mod buggy? I am running a 8.5 and currently run a Tekin rs. Also, what is the correct program box for it? Thanks
hobdog is offline
