HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree194Likes
Old 08-03-2013, 10:35 AM
  #3841
rcboy1's Avatar
Originally Posted by sls7474
I have a Sct pro from Falcon that I bought the middle of May. The green light blinks constantly when it is turned on. It seems to run fine but the green light is always blinking. About 10 battery packs thru it with the light on. I thought the light meant temp too high? Motor is the 3656sd 4000 kv.
That usually means the esc is running is sensorless mode. if you are running without a sensor wire then you are fine, if you are then it is either damaged or not plugged in. Honestly though, running in sensorless with that motor is barely noticeable from sensored.
rcboy1 is offline
Old 08-03-2013, 10:42 AM
  #3842
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by rcboy1
what were your temps? were you running sensored?
I was running sensored. Motor was around 140-150 and esc around 115-120.
Rockthecatbox21 is offline
Old 08-03-2013, 10:44 AM
  #3843
I have just ordered a Hobbywing (#Combo-SCT-Pro-C1) XERUN SCT-PRO Sensored ESC +3656SD(4700KV) for my TLR 22 SCT truck running a 85t spur. What pinion size/sizes should I use to get the most out of this motor?
Also where can I find a base setup sheet so I can program the ESC accordingly?
Sivaaji is offline
Old 08-03-2013, 10:47 AM
  #3844
I'd try and cancel that order. The 3656 motor is for 4wd shortcourse. That 4700Kv motor is already insane for 4wd, would probably ruin your 2wd truck.
Old 08-03-2013, 10:53 AM
  #3845
Sorry mistake, the spur is 86t
Sivaaji is offline
Old 08-03-2013, 10:55 AM
  #3846
I thought red and green blinking was sensorless?
sls7474 is offline
  #3847
Oh no so what should I have gotten? Maybe too late to cancel so could I dial it down on the Programer
Sivaaji is offline
Old 08-03-2013, 10:56 AM
  #3848
Trader Rating: 0 Default
Oh no so what should I have gotten? Maybe too late to cancel so could I dial it down on the Programmer
Sivaaji is offline
Old 08-03-2013, 10:58 AM
  #3849
So which motor should I get that I can use with this esc?
Sivaaji is offline
Old 08-03-2013, 11:06 AM
  #3850
hkrob's Avatar
Trader Rating: 18 (100%+)
http://www.falconsekido.com/products...combo-x-series
X5A combo with an 8.5t motor is perfect for a 22sct. I am pretty sure you wont be able to mount that SCT-PRO esc in your 22sct its to big and wont fit on the esc tray.
hkrob is offline
Old 08-03-2013, 11:28 AM
  #3851
Originally Posted by poolebay
I am running the SCT Pro with a Tenshock SC411. I have read the following warning on the Hobbywing website. Do you have an expected date for this compatibility issue to be resolved?
I posted this question at the back end of June. Is there any news yet?
poolebay is offline
Old 08-03-2013, 11:36 AM
  #3852
babydaddy's Avatar
I think red and green flashing means "sensor error" then the esc switches to sensorless
babydaddy is offline
Old 08-03-2013, 11:46 AM
  #3853
Mine just blinks green all the time.
sls7474 is offline
Old 08-03-2013, 12:10 PM
  #3854
lewis110's Avatar
Originally Posted by Arsenal2012
I downloaded the V3.3 software and then updated my program card to this...
What does this do, is it even a upgrade?
Is this correct so far?
Where do I get the 508 firmware for the Justock Clubspec ESC. Is this the best firmware for this ESC?
How do I get the firmware on the ESC?
To get to the esc you need to click on the "device" tab in the left hand corner and go down to speed control.
I made a video on how to upgrade the firmware on an Xtreme Stock. The Justock will be the same way.
http://www.youtube.com/watch?v=jeaQQ...e_gdata_player
Hope that helps any more questions feel free to email me at [email protected] I can even talk you through it if needed.
Roger
lewis110 is offline
Old 08-03-2013, 12:21 PM
  #3855
rcboy1's Avatar
no issues on temps then. if you were running high timing id reduce that a bit. was the esc hard mounted?
agreed. you could probably run that motor in an 1/8th scale if you run on a small track. id try either the older hobbywing 540s or the new v10s with a 7.5-8.5 motor.
rcboy1 is offline
