HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 07-22-2013, 10:06 AM
  #3751
TCCustoms's Avatar
Originally Posted by Wildcat1971
I am running the v2.1 xerun with a HW 4000kv 4 pole in my scte 2.0. The truck has so much power, that I am thinking its too much for me to drive well. Plus, I really dont like the work it putting on my battery. I am thinking of lowering my throttle end points. My temps on the esc are 120ish and the motor is 140ish. I have my punch all the way down. Anyone lowered the throttle epa? Any issues?
I wouldn't try it, last time i did it i didn't like the way the powerband was...i had the 4700kv indoors and it was WAAAAAAY to much and why I didn't like it
try changing your gearing or something else
TCCustoms is offline
Old 07-22-2013, 10:11 AM
  #3752
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
running a 14t with the stock spur now. Would going to a 12t lower the amp draw on the system?
Wildcat1971 is offline
Old 07-22-2013, 10:17 AM
  #3753
TCCustoms's Avatar
U could try 13, 12, or 11 but wheel spin would be the next issue cuz that to will create heat
Old 07-22-2013, 10:19 AM
  #3754
run_pais's Avatar
Trader Rating: 67 (100%+)
Originally Posted by thebizz
The ESC has constant power. The button doesn't turn it on or off. I have to unplug the battery to not have power to it.
Yeah I have the same deal. If you turn off your radio and then hit the button it will turn off. The ESC has loss of signal protection. I think thats the intended sequence of operations for this ESC.. or.. just unplug the battery..
run_pais is offline
Old 07-22-2013, 10:21 AM
  #3755
meh, I guess, I will just keep my finger out of the trigger. the motor is stupid fast, I dont see why people want 4700 and 5k + motors. I run on an 8th scale track, some others have a track 2x the size of mine.
Old 07-22-2013, 10:25 AM
  #3756
run_pais's Avatar
good suggestions!!... turn boost down in addition to punch that draws amps too and heats the motor. gear it down a tooth and see if you like it..
also, i have turned down my end points in the past with no issues
run_pais is offline
Old 07-22-2013, 10:44 AM
  #3757
lol, I am not boosting that motor.
Old 07-22-2013, 10:48 AM
  #3758
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
lol. liking mine for sure (4000Kv). Have you tried maybe a different software on the ESC? Maybe that could mellow things out?
Cain is offline
Old 07-22-2013, 10:53 AM
  #3759
I am running the most recent mod firmware. The blinky had crap for breaks. But i bottomed out the timing, turbo and punch.
Old 07-22-2013, 11:12 AM
  #3760
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Anyone figure out the the fix for the SCT Pro ESC when running the Tekin 4600k motor. Mine is down to 3 on the punch setting and it still stutters so bad when I hit the throttle from a stop I am causing pile ups. 4 TQ's in a row and I almost get rear ended off the line every time. Its so bad that the other racers are asking me to upgrade to a RX8. It seems to be the sudden movement from neutral that causes it. My end point is turned down to 80% and even a half pull punch will make it happen.
Happy with the ESC and the smooth feel it has if this can be fixed with software. Changing to a different motor brand is not an option for me.
Cameron Kellogg is offline
Old 07-22-2013, 11:24 AM
  #3761
Tech Legend
Cain's Avatar
have you tried a different Tekin 4600Kv motor? wondering maybe an issue with the motor, or, does the motor work fine with other ESCs?
Cain is offline
Old 07-22-2013, 11:25 AM
  #3762
run_pais's Avatar
i believe he problem is with the tekin motor... they dont do well with hobbywing ESC's which try to run sensored all the time.
I strongly urge you to try the hobbywing 4000KV 4 pole motor over getting the RX8.. you will not be disappointed!! I can almost guarantee it!!
btw, i had the pro4 4000KV motor before switching to hobbywing so I have used both motors; In my opinion the hobbywing motor is better... no kidding!! I prefer the 400KV motor over the 4700KV motor even on larger tracks.
run_pais is offline
Old 07-22-2013, 11:37 AM
  #3763
My racing buddy and I are going to try and swap out Tekin motors to see if it might be the sensor board on mine.
We have a track rule no passing through the first corner so when my truck does not move everyone has to jam on the brakes and wait. They are getting pist at me.
I understand that its in Hobbywings best interest to want people to use their motor with the ESC but the Tekin Motors are very popular in this class. I post for thebigSC and wanted to try a more cost effective choice for racers and do a write up on it. Seems this could be a problem fixed with software. I am plenty fast with it and have the track record in the class currently. I just need to move from a stop quickly as possible.
Old 07-22-2013, 11:52 AM
  #3764
Tech Legend
Cain's Avatar
Cool. Let us know how it goes.
Agreed with others assessment, the HW 4000Kv motor is a beast in comparison to the Tekin Pro4 4600kv. And I think its a bit better than the Pro4 HD motor I had. This mind you is with a Speed Passion ESC, but, from what I understand the GT2.0 series was made by HW for speed passion, so kind of a cousin here
Cain is offline
Old 07-22-2013, 12:57 PM
  #3765
RoyB's Avatar
Trader Rating: 19 (100%+)
Originally Posted by MOmo
So i tried searching, but didn't find anything that would help me.
Brief background:
I currently run in my 2wd stock buggy, the HW120a ESC with BLACK case : XERUN-120A-SD V2.1 (Blue): 81020171 and set for "Blinky"
I have 2 of the HW LCD programing boxes (One was formatted and programed to use with my SpeedPassion ESCs and software. ) The 2nd one is left in "Stock" form with the V1.07_110119 software.
I have a couple of questions. Can I safely update the HW Prog. box to the latest software or will it ONLY work with the newer V3 escs? What is the recommended software version I can still use with my V2.1 esc?
Now, part 2.
I just got a HW 35A esc pn#81010130 ( http://www.hobbywing.com/product_show.asp?id=253 )
I plan to mate it with a Fuze 3300KV motor and install it in a CupRacer drift car. I had hoped to simply hook up my LCD programmer and flash the 35A to adjust the settings, but alas, it doesn't seem to get recognized.
I seem to get the infinite "Connecting ESC" msg, (when I have the battery connected to the ESC by itself) or when I have the ESC and Programming box connected to my computer via USB, I still get Connecting ESC.
Based on the HW page (see link above), it indicates that my 35A esc IS capable of using the LCD Prog. box. Will I lose anything by updating the software? Firmware? USBLink? - (currently v3.1) I want to be able to adjust my 120A ESC as well as this one IF possible. Please Help.
MOmo
I use a LCD programing box for my V3.1, xtreme stock and a 35a ezrun esc and have no problems using it for all of them
Angelo posted something on the Hobbywing onroad thread about the box not working with a 1s battery.
http://www.rctech.net/forum/electric...tware-739.html
RoyB is offline
