HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree194Likes
Old 06-13-2013, 08:42 AM
  #3301
spookie's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Cain
thanks for the info. was looking at this BEC from hobbywing:
http://www.ebay.com/itm/150843383515...84.m1438.l2649
Nice, that should be plenty of power for dual servos. Plus that shows up to 10S I assume?
spookie is offline
Old 06-13-2013, 08:51 AM
  #3302
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
yup. I was going to try my setup first then order, but, maybe I'll just order it since its not exactly putting me on the bread line lol
was debating this or the castle blue one. any opinions on either? I like the fact you can adjust the voltage on the castle one, but I am thinking maybe the one I listed is more robust.
Cain is offline
Old 06-13-2013, 08:53 AM
  #3303
spookie's Avatar
Nice lol. In the end it's well worth it lol. Here's one from yesterday. It's my wallpaper now.
Eta, I'm not sure on the Castle, haven't heard anything for or against so far.
spookie is offline
Old 06-13-2013, 09:18 AM
  #3304
Trader Rating: 33 (100%+)
The castle works well, adjustable per .1v, supports 6s, but requires their programmer to do anything other than stock (6a I believe). There also isn't an off/on switch, so dependent on how you wire it up, the system may never turn off unless you do something special or unplug your battery.
I have no doubts the hobbywing works well also, but make sure you get the right model for the number of cells you run. Some support up to 10s, some only 3. Unfortunately I am not seeing anywhere where they are programmable other than minor adjustments from ~5 to 6v. Hopefully they have something new in process to support all the higher voltage servo's available today. Even if it isn't adjustable via software per say, a switch for 6.0v to 7.4v instead would be great.
RokleM is offline
Old 06-13-2013, 09:24 AM
  #3305
I'm waiting on some good 6s lower kv motors and I'll be switching this one to hobbywing Prototype we have geared way down and suspension limited so it doesn't pull wheelies like crazy. Geared to only hit ~50 on the straight
(my junk test body)
RokleM is offline
Old 06-13-2013, 09:25 AM
  #3306
Tech Legend
Cain's Avatar
thanks for the heads up. I decided to give the hobbywing one a try, the HV one.
For my needs, 6V is sufficient, just need to power 2 servos, hitec 7955TG for a 1/5 scale savage conversion I have.
By the way, is there any failsafe feature in the bec, such that if it fails, it does not send all the voltage to the servos?
I have heard the castle one if it fails can send all the voltage to the servos, smoking them.
Cain is offline
Old 06-13-2013, 09:29 AM
  #3307
You can crank those too, FYI. I'm running 8.0v on mine in the vehicle above. Specs are hard to determine since they don't advertise it, but hypothetically it would be around 450oz, .07 - .10 sec.
Let us know how that hobbywing BEC works, I might want to pick up a couple of them.
RokleM is offline
Old 06-13-2013, 09:36 AM
  #3308
spookie's Avatar
Haha, very cool RokleM. The funny thing is, it's hard at pretty much any speed to not pull wheelies, and it's geared more for speed at this point 20/66, haven't clocked it yet, but calculates out to 48mph. I don't have enough room to really open it up, but at 30mph it starts trying to creep up into a wheelie and anything other than a medium acceleration lol, with the punch at 3. I'm super pleased with this setup for sure, even with the glitching.
@ Cain, I wondered if you were building a 1/5th. You have to let me know when you shoot some vid, I would love to see that setup on a 1/5th. Haha, for sure crazy. Ok, I'll shut up now lol.
spookie is offline
Old 06-13-2013, 09:42 AM
  #3309
Yeah, the red straps on the arms/tower are limiters on this setup.
RokleM is offline
Old 06-13-2013, 09:56 AM
  #3310
Tech Legend
Cain's Avatar
Will do, may not be the best in the world with the camera I got but I do have some pics of what I am going to use it in.
Cain is offline
Old 06-13-2013, 05:01 PM
  #3311
Slotmachine's Avatar
Here are my setting for a 4000kv motor with theV-3 in my Tekno SCT410
1st punch rate 8
2nd punch rate 20
boost timing 15
boost timing start rpm 20,000
boost timing end rpm 60,000
turbo timing 12deg
full throttle delay 0.2
turbo timing start rpm 26,000
The wheels on my truck look like pizza cutters going down the straight and keeps up with 8th scale buggies. These settings are going to push your batteries to the limit...
Paul Rush
HWNA
Team Driver
Slotmachine is offline
Old 06-13-2013, 05:22 PM
  #3312
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
1st punch rate 8
2nd punch rate 20
boost timing 15
turbo timing 12deg
Paul Rush
HWNA
Team Driver
what pinion gear are you using?
DriveItLikeYSIT is offline
Old 06-13-2013, 06:19 PM
  #3313
I`m using a 15 pinion on a 150 foot straight, lap times are 35 seconds on average.
Paul
Old 06-13-2013, 07:40 PM
  #3314
Arrow
Paul
I wonder if I'm overgeared? I have a HW Sct Pro v2 with 4700kv motor & 70c, 7200mah packs ..I'm using a 15t pinion with punch of 3 & little to no timing. I usually race at small to medium size indoor track with a 50ft straight & 14 to 15 second lap times..
http://youtu.be/_B2flip3IGc
I was using a 14t pinion with 15 degrees on timing but couldn't consistently clear the back table top.
Old 06-13-2013, 08:55 PM
  #3315
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
1st punch rate 8
2nd punch rate 20
boost timing 15
turbo timing 12deg
Paul Rush
HWNA
Team Driver
i'm using a 16T pinion and the following settings:
1st punch rate 5
2nd punch rate 5
boost timing 10
boost timing start rpm 12,000
boost timing end rpm 40,000
turbo timing 5deg
full throttle delay 0.0
turbo timing start: full throttle
that's on a big track. if i'm running on a smaller outdoor i'll bump the boost up to 15 with 0 turbo. when i run on our small indoor track i don't run any boost or turbo.
RC*PHREAK is offline
