HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 06-03-2013, 03:51 PM
  #3151
REDdawn6's Avatar
Originally Posted by Rockthecatbox21
2s lipo or 7 cell nimh would be the only "ideal" setup for that motor and vehicle.
What HW ESC would you recommend?
REDdawn6 is offline
Old 06-03-2013, 04:07 PM
  #3152
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
I would think the ezrun SC8 would be perfect for that.
Rockthecatbox21 is offline
Old 06-03-2013, 04:32 PM
  #3153
TCCustoms's Avatar
SCT Pro...but thats me
TCCustoms is offline
Old 06-03-2013, 06:40 PM
  #3154
Slotmachine's Avatar
Originally Posted by Prostreet314
Why is it that every time I go to order a black sct pro it's out of stock? I don't want a blue one... more waiting I guess
Take a big black magic marker to it......kidding..... Actually I like running the blue ones, that way without question you can tell its a Hobbywing
Slotmachine is offline
Old 06-04-2013, 06:43 AM
  #3155
if you run with 2s-3s, the hw sct pro esc and v3.1 or v2.1 esc is good for ya
but if you run with 4s-6s, then xerun 150a esc is really good for ya,
i suggest to use combo, because many pluses you can get with combo HW
like temp cutoff, but in many cases it wont go further than 130 degrees
j3fron is offline
Old 06-04-2013, 06:47 AM
  #3156
Trader Rating: 20 (100%+)
When using the multifunction programming box to read 2s lipo cell voltage, it always reads one cell low. I checked the voltages with a multimeter and they were spot on. So it is defiantly the programming box.
kyleman7 is offline
Old 06-04-2013, 10:06 AM
  #3157
TCCustoms's Avatar
as in 3.2v is actually 2.2v
or
3.2v is actually 3.1v?
Old 06-04-2013, 10:11 AM
  #3158
Trader Rating: 33 (100%+)
or
I assume he means that if it's a 3.2 x 2s, it's only reading 3.2 instead of 6.4?
Never tested it myself honestly.
RokleM is offline
Old 06-04-2013, 10:20 AM
  #3159
TCCustoms's Avatar
exactly why im asking him since he didnt give alot of info so its hard to help w/ a lack of info and im not gonna assume i kno whats going on without that info to help him
not to sound rude...but thats why im asking for more info to help him becuz the LCD box states its reads within so any volts and doesnt claim to be 100% exact
Old 06-04-2013, 10:40 AM
  #3160
Lets say the the cells are at 3.2 each it might say cell one is at 3.12v and cell two is at 3.2 v where as my multi meter and charger says both are at 3.2v
Keep in mind these are made up numbers at this time but explains the kind of problem I'm seeing. I can get some real numbers when I get home from work.
kyleman7 is offline
Old 06-04-2013, 10:49 AM
  #3161
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
you vm, charger and balance checker should all readthe same, because they all read from the same source, the 3 pin balance connector. Resistance might be different because of differences in interfaces and wire lengths and gauge. If your using a $1000+ volt meter, then its probably more correct than a $25 led box... Chargers can be off and some actually have a calibration mode where you can adjust it with a high quality volt meter.
Wildcat1971 is offline
  #3162
I dont think it is intended to give the most accurate reading like a multi-meter does. I think it is intended to let you know if the battery is charged or not, so you don't put a dead battery in your car before a run.
Paul Rush
HWNA
Team Driver
Old 06-04-2013, 11:17 AM
  #3163
rcboy1's Avatar
If anybody has any questions on what esc or motor they should use for a certain car or truck, you can either pm me or ask here, those are the kind of things i know
rcboy1 is offline
Old 06-04-2013, 12:23 PM
  #3164
Derry's Avatar
Trader Rating: 27 (100%+)
Yup, threw me for a loop as well. I plugged mine in and figured one of the cells must be weak or something. So I throw my blinky balancer on it and it didn't do anything... So I broke out the multimeter and bam! They were in perfect balance.
Paul Rush
HWNA
Team Driver
Yeah, I figured as much. I wouldn't think it would be to difficult to make it accurate though. Maybe a future software upgrade will address the issue.
Derry is offline
Old 06-04-2013, 02:21 PM
  #3165
@ cobraracing
Originally Posted by yacagree
Hi, didn't you receive my email 5 days ago? Or no idea?
I reinstalled V3.3 a few times but only Data Base Version 130511 will be displayed which I updated 3 weeks ago. No newer versions available.
Maybe you didn't read it, so I try it again. Is there a bug in V3.3 and do I wait for V3.4, because I can not update to the newer ESC firmware?
yacagree is offline
