HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree194Likes
Old 06-02-2013, 09:04 PM
  #3121
Originally Posted by DriveItLikeYSIT
I also use the HW 4700 kv w/ out a fan at a large outdoor track in FL and have never thermalled. What was your gearing ?
Started with 15 the first go around two weeks ago, did not thermal. Jumped up to 16, expo at 50% and travel at 80% on my radio. Outside temp reached 100-101 today by the time the main came around.
After the heats was temping around 145. Asked a couple guys at the track and said I was ok, but getting on the warm side.
teknorookie is offline
Old 06-02-2013, 09:21 PM
  #3122
Are there any Canadian dealers that have the sct motors??
george919 is offline
Old 06-02-2013, 09:31 PM
  #3123
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
When its real hot outside I use a 14t pinon with 20 plus degrees of esc timing or 15t w/ less than or equal to 15 degrees of timing. Other guys use higher gears with motor heatsinks and fans but my set up is just as fast..I also have a NIP 16t pinon in my tool box but I've never had to use it. I gear my setup so I can clear the largest jumps on the track..
DriveItLikeYSIT is offline
Old 06-02-2013, 09:43 PM
  #3124
Will give that a try. It's only going to get warmer out here. Thanks for the tip.
Old 06-02-2013, 10:23 PM
  #3125
Vegatron75's Avatar
Had a problem at the start of the main last night. After a couple of minutes of warm-ups, we lined up for the main.
The tone goes off and I hit the throttle and nothing happens. It had steering but no throttle.
This has happened onece or twice before, same scenario, start of the main.
Luckily they restarted the main, I was TQ, and it worked fine for the 8 min. main.
Haven't had any issues other than the starts.
The combo is the sct pro w/ the 4000kv 4-pole motor, geared 16t pinion in a tekno truck.
Thinking it's a dead spot on the board? but pushing it doesn't seem to fix the problem.
Any ideas?
Vegatron75 is offline
Old 06-03-2013, 02:59 AM
  #3126
Hi Vegatron75,
I had the same problem like you with my first SCT Pro. I searched a long time but couldn't find a solution. I bought a new SCT Pro and till now no problem.
If you find out a solution, please tell it.
yacagree is offline
Old 06-03-2013, 03:12 AM
  #3127
Unhappy
Originally Posted by COBRARACING
Send me an email at [email protected] and i will sort it out for you
Hi, didn't you receive my email 5 days ago? Or no idea?
I reinstalled V3.3 a few times but only Data Base Version 130511 will be displayed which I updated 3 weeks ago. No newer versions available.
yacagree is offline
Old 06-03-2013, 03:26 AM
  #3128
Default SCT Pro
Hi guys, I have SCT Pro esc in my 1/8 buggy. This is the motor I'm running: http://www.hobbyking.com/hobbyking/s...or_2100KV.html
The problem is with the red and green led blinking together. I've set punch to 1, set the number of cells but it does not help.
Do you think I should update the firmware?(I don't have lcd programmer yet)
Thanks for help
from_Poland is offline
Old 06-03-2013, 04:54 AM
  #3129
Slotmachine's Avatar
Thanks for help
Isn't that motor like that Tenshock one that has some compatibility issues? I`m not sure but they look a lot like them. Have you tried a new sensor wire, or running it with no sensor?
Paul Rush
HWNA
Team Driver
Slotmachine is offline
Old 06-03-2013, 05:57 AM
  #3130
Trader Rating: 20 (100%+)
Any ideas?
I've had similar issues with my tekno running the sct pro and a 4600kv tenshock sc411 and a 16t pinion.
Hi Vegatron75,
I would really hope that buying a new speed control isn't the solution.
kyleman7 is offline
Old 06-03-2013, 07:16 AM
  #3131
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Any ideas?
If you read the sct410 thread, you must have seen the 2-3 pages where i was trying to correct the exact same problem. The only difference between me and you is, i was running a castle mmp, but we both had the same problem. Truck just stops randomly, has steering, but no throttle. I switched to my backup mmp and everything was "fine". The truck has great punch for the first 3 mins or so, and then the power slowly drops off. I corrected one peoblem, but ran right into another. Right when i'm about to go purchase a new sct-pro, all this crap comes up again. Wish i could buy and not worry if i'm gonna have problems like so many others on here. My only other option is the V3 esc, but the price tag kills me. I'd like to trust hobbywing, but with all these problems popping up on here lately, i might just have to wait.
Rockthecatbox21 is offline
Old 06-03-2013, 07:40 AM
  #3132
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
HW used to be the bomb with the v2.1 series esc's. In fact I know many people running the hw4k and 4700 with the v2.1 120 esc's. And they do so without issues. I plan to run the v2.1 series esc's in my 4x4.
Wildcat1971 is offline
Old 06-03-2013, 08:10 AM
  #3133
I`m now running the V3 with the 4000kv motor in my Tekno SCT 410 and I have to say it is very good. I am running some timing and boost with no issues.
How old is your sctpro that is shutting off during your race? If it is still under the warranty get an RMA# and send it in for repair or replacement, if it is a problem with the unit it should be covered. I know Hobbywing is very proud of its customer service and tries to treat their customers in the best way possible. Shoot off a mail from their site explaining your problem and get an RMA...............
Paul Rush
HWNA
Team Driver
Old 06-03-2013, 09:19 AM
  #3134
Any ideas?
I had this happen to me a couple of weeks ago. I ended up bypassing the on/off switch by soldering the black and red wires together and leaving the white one connected. The esc stays on whenever the battery is plugged in now, but that is not an issue for me because I always unplug my battery when I am not racing. The white wire controls the calibration button so it is still functional. So far I have not had the problem again (knock on wood).
dirtracin58 is offline
Old 06-03-2013, 09:31 AM
  #3135
Where can I buy hobbywing motors in Canada?
