HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 05-25-2013, 06:58 PM
  #3001
COBRARACING's Avatar
Originally Posted by EricW
Just installed my first Hobbywing Just Stock esc today. According to the book after setting the calibration of the throttle/neutral/brake the green light on the speedo will flash. I get a flashing light but it's not green it's red, speedo seems to work fine even with the flashing red light.
Is this normal? Or should the light really be green instead of red? Only asking because there are other typos in the book like it says the "motor" will beep during programing, I assume they mean the esc as it's the only thing that beeps when making settings changes.
Flashes red when you throttle thats normal if flashing green means over temp .
Yes there are some typos.
Happy racing
COBRARACING is offline
Old 05-26-2013, 06:59 AM
  #3002
Just got this 120a combo, the motor inside is 8.5T, 4000 KV.
Is the motor suitable for heavy offroad 1/10 ep buggy ? (lots of long jumps in big track)
I notice the case has lots of venting holes as well, might invite dust and clay in my dusty track.
Is this an on road motor actually ? My other brushless motors usually use fully closed case.
Attached Thumbnails HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-dsc_8932.jpg
redtags is offline
Old 05-26-2013, 07:55 AM
  #3003
lewis110's Avatar
That motor will work great in a buggy. Don't worry about the holes, that's for better cooling. Just blow the motor out with an air compressor during your maintenance.
lewis110 is offline
Old 05-26-2013, 08:09 AM
  #3004
Default Thermal gap filler
Can someone please provide the specs of the thermal gap filler used on the 1/8 esc. Used between fet's and heat-sink
charl is offline
Old 05-26-2013, 08:21 AM
  #3005
will the sct work well in a 1:8 buggy?
1bb3 is offline
Old 05-26-2013, 09:00 AM
  #3006
HI Lewis thanks for the info on those gaping.
How about the KV number ? Not too high ? I'm thinking about something in 3300 KV to run cooler and higher torque for long jumps actually.
Will a sensor cable from hobbyking fit as a replacement for stock sensor cable? Just broke mine while trying to unplug it from the esc.
And is there a safe way unplug this cable ? I notice there is no space on the plug to grab on.
redtags is offline
Old 05-26-2013, 09:38 AM
  #3007
lewis110's Avatar
Just installed my first Hobbywing Just Stock Cub Spec esc today. According to the book after setting the calibration of the throttle/neutral/brake the green light on the speedo will flash. I get a flashing light but it's not green it's red, speedo seems to work fine even with the flashing red light.
Also, what program box can I use with this speedo?
You will want to use the 2-1 LCD program box.
http://www.falconsekido.com/products/lcd-program
lewis110 is offline
Old 05-26-2013, 09:41 AM
  #3008
R/C Tech Elite Member
EricW's Avatar
Thank you
EricW is offline
Old 05-26-2013, 09:49 AM
  #3009
lewis110's Avatar
It's not uncommon for guys to be running a 6.5 in nights. I say if your new and don't have much throttle control then use a 10.5 or 13.5. I believe a 8.5 wood be pretty good through. My personal preference is I like to know I have more then enough motor. You can always turn your transmitter down if you have to much.
All sensor cables should be the same. So it should work. I know I too have pulled a wire trying to unplug it. I just wank on it and pull it out.
lewis110 is offline
Old 05-26-2013, 10:53 AM
  #3010
machocave's Avatar
Originally Posted by COBRARACING
Justock does come with the fan as a standard feature.
Thanks for letting me know Just saving up a little more and I'm ordering one
machocave is offline
Old 05-26-2013, 12:17 PM
  #3011
I seen people run the v2.1 xerun with out a fan on 4x4 sct is this advisable?
Sierrahotel is offline
Old 05-26-2013, 03:27 PM
  #3012
I have the USB Link V3.3 but it shows only the version V1.00_130509a_2R for my SCT-PRO. V1.01_130515a_2R should be available but not for me. Any ideas why not? Thanks
yacagree is offline
Old 05-27-2013, 02:36 AM
  #3013
You've been a tremendous help and very informative, really appreciate your reply.
I'll install this 8.5T with confident.
redtags is offline
Old 05-27-2013, 05:47 PM
  #3014
Got a problem.
Have been running a brand new 150a/4274 combo for last few days flawlessly. Just this afternoon I took it for another run, turned it on with a fully charged 4s, and it stopped after 30 seconds. Throttle and reverse stopped responding. No smoke or smell. Servo worked fine. Turned the ESC off/on again and no beeping sound, although it did flash green 4 times as it usually does when registering the 4s.
Thoughts?
nvision is offline
Old 05-27-2013, 05:51 PM
  #3015
Originally Posted by nvision
Got a problem.
Thoughts?
No throttle signal two issues either your battery is low which like you said is fully charged or some loose connection to your receiver rx cable .
