HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 05-11-2012, 08:28 PM
  #271
Suspended
when I turned on my xerun 150 recently it beeped the cell count like normal then just let out a puff of smoke and died. it was working great before that. is it fried for sure? would it be cost effective to fix it or will I have to buy another?
Tekno_Jammin is offline
Old 05-11-2012, 09:15 PM
  #272
RCmayor's Avatar
Yep, smoke means a component burnt up. If it is out of warranty it would probably cost 50-60 bucks to fix it with parts labor and shipping. For 100-120 you can get a new one.
RCmayor is offline
Old 05-12-2012, 12:23 AM
  #273
IROC-AR15's Avatar
Trader Rating: 29 (94%+)
Hell cheaper than that sometimes for like $79. That's one the good things about the esc the last a long time yet aren't that costly to replace. Great bang per buck by far
IROC-AR15 is offline
Old 05-12-2012, 10:21 AM
  #274
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
That is a little unsettling hearing that since i got the same esc in the mail yesterday. Really hope that doesn't happen to me twice (my mmp died and i got the hobbywing). I think you had to do something wrong beforehand, because i've only heard great things about this esc. Might have been just a fluke though.
Rockthecatbox21 is offline
Old 05-12-2012, 11:16 AM
  #275
9six7nine2bOI's Avatar
Trader Rating: 20 (100%+)
will the hobbywing lcd program box work with speed passion gt 2.0 esc with the lastest soft/firmware
9six7nine2bOI is offline
Old 05-12-2012, 11:24 AM
  #276
RCmayor's Avatar
Yes, the box never has any firmware in it. It just reads whats in the speed control.
RCmayor is offline
Old 05-12-2012, 03:47 PM
  #277
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
does the xerun 60a have a "blinky" mode for spec racing?
RC*PHREAK is offline
Old 05-12-2012, 03:53 PM
  #278
lewis110's Avatar
Yes, when you hook it up to the computer there will be a filmware for that. Sorry I can't think of the numbers. It will day ---no rev.
lewis110 is offline
Old 05-12-2012, 11:49 PM
  #279
Got my hobbywing 150 amp xerun esc yesterday and soldered on the connectors today. I got the optional 2 in 1 LCD programming card. In the box it has a web address to get the software for the computer to connect through the included usb. Tried to go the url but it says it cannot be found. What gives?
Had to program it manually because of this.
Old 05-13-2012, 04:09 AM
  #280
lewis110's Avatar
You can still use the program box, It's faster anyway. You can download it off hobbywing's website. You can also download it off CRC's website.
lewis110 is offline
Old 05-13-2012, 10:23 AM
  #281
will i be able to upload a more recent firmware via hobbywing lcd program box?
Old 05-13-2012, 05:02 PM
  #282
IROC-AR15's Avatar
Yes I swap firmware all the time playing with settings. The LCD Programming box is very easy to use and update sir.
Old 05-14-2012, 06:53 PM
  #283
Default Problem with initial Setup - Blue 150A Xerun
So I go through intial setup i'e, one green light neutral, two green lights full throttle,, three green lights full brake. Then...i once programmed it hits full throttle without me touching anythig. I tried programing a few times, shutting the esc off after programing, and still, once programmed when i turn the esc n after programming, it send full power to the engine and i have no transmitter control over the throttle whatsoever.
Help. Do I have a bad ESC?
2100kv motor - 4s
DADDIO is offline
Old 05-14-2012, 08:08 PM
  #284
2100kv motor - 4s
Do you have the 2 in 1 esc lcd programming card? I never had to go through manual setup with mine. I just changed some settings on the programming card and my truck worked fine.
Old 05-15-2012, 01:25 AM
  #285
IROC-AR15's Avatar
Same thing here. I use the lcd and there is no initial setup associated with programming the combo. Have you ever used this setup b4 attempting to prgm? Also are you running sensored and if yes to that how are your wires running from esc to motor? I'm just trying to visualize your setup. What's your operating system on your machine? iOS or Windows? We gotta ask ourselves questions to narrow it down.
