HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 03-22-2013, 06:12 PM
  #2371
lewis110's Avatar
Originally Posted by Morpheus847
ok, got the 930 software loaded works great so far. I just ran boosted 17.5 in my short course with the stock software. With a 10.5 in buggy would it be best to run the stock software or mod software?
For a 10.5 i would still stick with the stock firmware.
lewis110 is offline
Old 03-22-2013, 07:35 PM
  #2372
Vegatron75's Avatar
Been having a few issues w/ my SCT pro esc. The current layout has a real short run up to a small jump that you need to hit full blast.
A couple of times I've went to hit the approach to the the jump and had nothing, no acceleration.
Doesnt' seem happen very often, but I'd still like to stop it.
No lipo cut-off, no thermal protection.
Running the 4000kv motor, Tekno SCT, Nano-tech Aspec 6200.
Any ideas?
Vegatron75 is offline
Old 03-22-2013, 08:04 PM
  #2373
Originally Posted by microracer25
What would be a recommendation for a esc running 17.5 blinky offroad?
I received previous recommendations to look at the Xtreme Stock for 17.5 blinky offroad buggy. I see that Falcon Sekido has the Xerun 90a on sale for about the same price as the Xtreme stock. Would the 90a be a good choice for 17.5 blinky, since it would give me the ability to run a lower turn motor?
http://www.falconsekido.com/products...0a-sd-esc-blue
microracer25 is offline
Old 03-22-2013, 10:38 PM
  #2374
Trader Rating: 90 (100%+)
Yes, the 90a amp is the latest xerun design and it's perfect for stock racing. The only drawback is that you will need the programmer and computer to load the blinky firmware. I own the 120a and 90a and can't tell difference when running 17.5 or 8.5.
Also, The Xtreme stock is only a 60A.
Kuya_Kimo is offline
Old 03-23-2013, 06:27 AM
  #2375
So, the Xtreme Stock is already in "blinky" mode? Can the Xtreme Stock have timing or boost, etc added to it?
If I went with the 90a, what would I need to program the software? LED program card, LCD box and a USB Link?
Sorry for the questions, I am not familiar with Hobbywings products.
Old 03-23-2013, 07:13 AM
  #2376
run_pais's Avatar
Trader Rating: 67 (100%+)
Any ideas?
hi,
it could be many things causing this. It looks like you are going from brakes to full throttle to get past the jump. which could mean you are having something to wierd going on with the start rpms or when suddenly drawing lot of current to get past the jump. Does this happen when the battery is fresh or only after a few laps??
- First check the wiring from motor to ESC if one of them is slightly loose your motor will run but you will loose power on sudden acceleration and your top end will be lost too.. happens to the best of us
- if not that replace your sensor wire.
- if you are using bullet connectors to your battery make sure you are not using the cage type connectors used for charging batteries. They will not be able to handle the current required and when you go from brakes to full throttle you are pulling a lot of current.
(I think im running out of ideas now)
- for fail safe I put a glitch buster on my receiver so when the receiver system is current starved the cap can drive the system. This is usually seen as a loss of steering and throttle power for a split second which might be the difference between making the jump or casing it.
run_pais is offline
Old 03-23-2013, 07:25 AM
  #2377
Vegatron75's Avatar
Originally Posted by run_pais
hi,
Full charge or less doesnt' seem to be an indicator. The few times this has happened didn't show one way or the other.
This little jump has no braking going on, little 180 into a small step-up and then "full blast".
My soldering skills are ok, motor wires are ok, sensor wire is pretty new.
I'm using the solid bullets. Although, the nano=tech battery holes seem to be a little larger than the bullets that I have.
I'm going to try some castle bullets and see if they fit a little tighter.
Also going to use a glitch buster next time I run it.
This sudden loss of power is very infrequent. It's still a problem though. Last race, I cased this jump and a the 2nd place Losi landed on me, luckily my truck held and he bounced off, otherwise this could have cost me....
Old 03-23-2013, 07:38 AM
  #2378
maddog9's Avatar
Trader Rating: 30 (100%+)
wrong area sorry.
maddog9 is offline
Old 03-23-2013, 02:27 PM
  #2379
Originally Posted by rippen
I have a 3656SD 4700KV coming, what pinion gear should I use in a SC10 4X4 with a 62 tooth spur.
Anyone
rippen is offline
Old 03-23-2013, 02:39 PM
  #2380
run_pais's Avatar
lets see...
- we still got the bullet connectors. The ones I have are split so you can spread them with a flat head to ensure a good fit. Not sure if yours is different or solid; this is important! PAul Rush was helping a guy out and he realized he was using the caged connectors and once we changed it his issue was resolved. his car would lose power intermittently too.
- try the glitch buster
- also maybe try running a different battery, maybe the one you got is spent.
Theres lot of team drivers who visit this forum and we will be happy to help you figure this one out.
run_pais is offline
Old 03-23-2013, 02:44 PM
  #2381
run_pais's Avatar
Anyone
on the sc10 4x4 with the 4700KV motor try 12T. go up or down 1 tooth depending on the size of the track.
run_pais is offline
Old 03-23-2013, 05:50 PM
  #2382
TCCustoms's Avatar
Anyone
I used 13t on my SCTE with 13/40 gearing and it ripped
TCCustoms is offline
Old 03-24-2013, 01:15 PM
  #2383
Trader Rating: 21 (100%+)
Default hobbywing v3
Can someone post a good setup for the v3 in a 4x4 sct. I would like to try one and am looking for a good starting point.
wkidder is offline
Old 03-24-2013, 02:11 PM
  #2384
Are the servo taking a vacation at the same time also? This happened to me, and it was my servo drawing too much amps.
ridgeracer is offline
Old 03-24-2013, 04:08 PM
  #2385
Default XERUN 120a SCT PRO issues
Hi. I recently purchased a xerun sct 120a esc from my local hobby shop. I installed it with a sensored trinity d3.5 17.5 turn motor and 2 cell, 5000Mha, 30C LiPo battery in my Associated SC10. I programmed it according to the instructions.
I had been running the Associated XP SC700 speed control and Reedy 3300kv motor. Everything ran great with this set up.
When I put in the new speed control, I started running it with the default settings. When I pulled the throttle the truck ran slow for about half a second and the green light came on and then after half a second both lights came on and it went full speed. I thought it might be the punch mode, so I tried several different levels from 1-9. Each setting, the same thing happened.
Also, as I was racing, when I would go full speed down the straight away and then slow down to make a hairpin turn, when I start to pick up speed again, the truck pretty much dies. There is no throttle and it just rolls for about 3-4 seconds. The throttle is unresponsive, but the steering keeps working as it should. As long as the truck keeps moving, it works fine. When it stops, the half second delay in throttle happens. When it goes full speed and stops, it takes 3-4 seconds to respond again.
The other thing that happens is when I change any of the settings, the motor becomes reversed. I have to change the settings, then go into the "motor rotation" setting and switch it.
I have tried 2 different motor sensor wires, and 2 different batteries, 2 different controller/receivers as well as 2 different motors. I've tried just about every combination of settings in all 12 items.
Do you have any ideas? Is there a setting I'm not getting? I just bought this on March 21. Is there anything I can try? I'd love to not have to send it away since I pull all my connectors on it and don't want to be without a speed control for too long.
Thanks for your help.
whitey_75 is offline
