HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree198Likes
Old 03-19-2013, 08:57 PM
  #2341
Guest
Originally Posted by rcboy1
Obviousley i'm a little biased on this subject (I think all the HW stuff is better), but there is a thread for the motor on here and there are pictures on there comparing the size of the magnets on the rotor between a tekin Pro4 and the HW....see for yourself.
(Hobbywing left, Tekin middle, then tenshock)
I haven't heard anything from him in a while, I'm assuming they're working on another project or something right now.
hey carter do u got the sct combo for ur corr truck????
kyoshoracer77 is offline
Old 03-19-2013, 09:20 PM
  #2342
rcboy1's Avatar
Not right now. I actually don't even own that truck anymore. When I did run that truck down there last year I was running the 4 pole motor, but instead of the SCT pro I chose a V2.1 to take advantage of its extra tuning features.
rcboy1 is offline
Old 03-19-2013, 09:46 PM
  #2343
Guest
y dont u have the corr truck from caster???
Old 03-20-2013, 09:28 AM
  #2344
jrz93's Avatar
Originally Posted by jrz93
I have 2 issues with 2.1 esc ?
My 60 amp esc will only run when sensor is disconnected
And 120 amp I cannot get the esc temp disabled??
Will the new V3.1 software help??
anyone?
jrz93 is offline
Old 03-20-2013, 10:37 AM
  #2345
lewis110's Avatar
anyone?
The newest pc software is the 3.2 and in not sure if that will help your problem or not. I burnt out the 1st phase on my xtreme stock once. It would run in sensorless mode but would not with a sensor wire hooked up. I had to roll the car to get the motor to work. That might also be your problem.
Do you have a lcd program box or led? I always leave my esc overheat protection turned on. If your not using a hobbywing motor chances are the overheat protection for the motor isn't going to work anyway. What's the reason you wanna shut it off?
lewis110 is offline
Old 03-20-2013, 11:04 AM
  #2346
richracer2's Avatar
Trader Rating: 51 (100%+)
I finally got everything hooked up to test the esc and motor (150a xerun)! This thing is sooooo smooth at low speed! I'll get to really test it today hopefully, I had to get a servo extention wire from the lhs today. But so far so good!
richracer2 is offline
Old 03-20-2013, 01:40 PM
  #2347
jrz93's Avatar
the 60amp issue i can understand
the overheat protection is in a 1s WGT onroad car and it stops car about 4-5 minutes in..the esc temp (with a fan) is always under 100 degrees F and Trinity d3.5 motor temps are 120-135 so idk why it says overload?
it is the single green flashing signal?
jrz93 is offline
Old 03-20-2013, 03:03 PM
  #2348
rcboy1's Avatar
We're still working on it lol
rcboy1 is offline
Old 03-20-2013, 05:41 PM
  #2349
Guest
have u had any problems out of ur 1/8 speed control????
Old 03-20-2013, 06:01 PM
  #2350
lewis110's Avatar
I'd have to look but I believe a single blinking green light might be low voltage cutoff also. But that wouldn't make since with a 1s battery. The voltage protection should be off. I don't understand why the overheat protection would kick on. I say download the newest 3.2 software and try it. What firmware are you running 508?
lewis110 is offline
Old 03-20-2013, 07:34 PM
  #2351
jrz93's Avatar
That is a good question
I just ordered the LED program box as I have the other box
Wanted to know if new firmware or software would help or an older version would?
I have several of hobbywing esc's n only the 2.1 120 amp 1s does this???
jrz93 is offline
Old 03-20-2013, 11:31 PM
  #2352
i have problem....
1 of my U terminal 3656sd motor got snapped.
i mean one side/corner of U terminal, not both....
and i managed to soldered again using that 1 piece side/corner of broken U terminal after i soldered with side/corner U terminal that still in contact.
my question....
if i broken both U side terminal, can i change with other terminal/conector with banana split conecctor?
or just straight solder it? can it hold up?
j3fron is offline
Old 03-21-2013, 12:58 AM
  #2353
darcness's Avatar
If you just straight soldered it, it should hold up. How did you manage to break it in the first place though? Must have been something that hit it pretty good.
darcness is offline
Old 03-21-2013, 05:14 AM
  #2354
lewis110's Avatar
Exclamation
You want the LCD 3-1 (or 2-1) program box. The newest blinky mode is 508_No_Timing and the newest boosted firmware is 930 stock/mod I would reflash the esc and it should let you disable the overheat protection.
The LCD is better in my opinion. With led is mainly just for Ezrun speedo's where they are pretty generic. The LCD will tell you exactly what you are programing. The led just gives you a number.
Roger
lewis110 is offline
Old 03-21-2013, 06:37 AM
  #2355
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Anybody know why my 150 amp xerun wants to cut my batteries off early? I programmed it to cut off 3.4 volts per cell, but it goes into lipo mode at about 3.7 volts per cell. Think i'm gonna program it for 3.2 V.P.C. to get it where i want the esc to cutoff at. My question is, why does it do this? I'm running a 1900Kv motor 4s 4100mah batteries. Esc wasn't hot, motor was warm.
Rockthecatbox21 is offline
