HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree194Likes
Old 02-19-2013, 08:55 PM
  #1951
If you have your punch settings set at 1 then you would basically not be using the punch control function ? The higher the number the less the punch the motor will have ?
evolution03 is offline
Old 02-20-2013, 12:04 AM
  #1952
nanoverse's Avatar
Originally Posted by straycat40
So the V3/4000kv 4 pole motor combo is OK for 4x4? I like the V3 features and wanted to try this combo.
That's what i've heard and a few are doing. Check out the v3.1 it has extra seals for keeping the dust out and a total aluminium heatsink.
http://www.eurorc.com/product/3391/h...0a-v31---black
nanoverse is offline
Old 02-20-2013, 12:17 AM
  #1953
nanoverse's Avatar
1 is either off or the lowest setting. The higher the number the more punch.
Old 02-20-2013, 12:18 AM
  #1954
Pygmy's Avatar
Hey, my apologies if this is a stupid question but I'm not clear on the effects of timing on my SCT Pro Esc + 3656SD motor. I've searched the forum but I haven't been able to find the info I need.
Does the timing influence the torque ? (I've read conflicting stories bu I'm inclined to believe that electronig timing on the ESC shouldn't influence Torque)
Am I correct in thinking that if I don't need more speed, I can best use Timing setting 0 on my Losi SCTE as the timing won't influence torque at all ?
Pygmy is offline
Old 02-20-2013, 12:35 AM
  #1955
nanoverse's Avatar
timing increases rpm and decreases torque. in 4-poles it's better to put timing to zero or when gearing doesn't help anymore a little.
So zero timing punch 3-6 and pinion 14-15 or even 16 on BIG track on a SCTE. I have it on 5 usually and 14 indoors 15 out.
Old 02-20-2013, 01:38 AM
  #1956
Pygmy's Avatar
Are you sure about the torque decrease ?
The way I understood it is that mechanical timing decreases torque, but electronic timing doesn't because the timing is applied proportionally with the rpm's (so no timing when still (thus no torque change), max timing at max rpm)...
But I've read a lot of conflicting things about this (I can imagine this behaviour could also be Esc specific).
Pygmy is offline
Old 02-20-2013, 01:47 AM
  #1957
nanoverse's Avatar
Basically it's either or. Do you wan't that the rotor moves faster or slower. In other esc's you can specify rpm ranges where you want to do either.
Old 02-20-2013, 01:54 AM
  #1958
Pygmy's Avatar
Ok, cheers.
Pygmy is offline
Old 02-20-2013, 09:43 AM
  #1959
NOLAG05's Avatar
I am going to be getting my xerun 150amp esc and the 4168 sensored motor for my 1/8 this Friday. Any of you guys running this setup that can give me pointers on settings your running?
Thanx!
NOLAG05 is offline
Old 02-20-2013, 09:38 PM
  #1960
darcness's Avatar
Thanx!
I'm running the SCT PRO ESC and a 4274 sensored motor. Amazingly smooth and the power is great. I don't think you'll be the least bit disappointed with it. Enjoy!
darcness is offline
Old 02-21-2013, 09:10 AM
  #1961
Brian Miskolczi's Avatar
Trader Rating: 162 (100%+)
New 1/10 motor:http://rcspecial.com/news/?p=122880
Brian Miskolczi is offline
Old 02-21-2013, 09:41 AM
  #1962
can anyone help with walking me through programming withoutt the card? I cannot seem to make sense of the online instructions. I have the older shiney blue 80a 1/8 esc
getloose is offline
Old 02-21-2013, 07:01 PM
  #1963
Trader Rating: 27 (100%+)
Having a problem with my Xerun 60a 2.1. Running a D3 and it seems to only be getting 25 percent power. Tried differnt profiles and what not still no change. Hooked the motor up to a friends Tekin and it woked like it should so I know the motor is good. Any idea where to start with this? Using a Spektrum DX2.0 and I did calibrate the esc/tx.
platinumjason is offline
Old 02-21-2013, 07:04 PM
  #1964
Slotmachine's Avatar
Make sure your radio end points are turned up all the way first, then calibrate the radio to the speed control.
Paul
HWNA
Slotmachine is offline
Old 02-21-2013, 07:06 PM
  #1965
babydaddy's Avatar
If you are running sensored
Disconnect the sensor cable and reboot the ESC and see what it does.
babydaddy is offline
