HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 01-14-2013, 05:18 AM
  #1606
BillyT.'s Avatar
Originally Posted by skipper_tim
1. Isolated my sensor cable away from the 3 motor leads.
This alone did not fix it but I believe this is just good practice.
I had this same idea... even wrapped the thing in foil. Have since removed the foil and the sensor wire runs right along the motor wires and I still don't have the issue.
And I gave up on bullet connectors for anything but my nitro starter box... They just really aren't meant for off road.
And the what you guys are calling the spring type bullets or bird cage... they are called banana plugs. Only meant to be used as charging leads, and nothing else. They aren't rated for ANY real kind of amp load.
Glad you got it sorted. It's a frustrating problem for sure.
BillyT. is offline
Old 01-14-2013, 10:48 AM
  #1607
Agree that the "spade" type bullet is the better choice -- I was already using that. (Protek parts from A-main). Maybe the nanotech batteries have a slightly "sloppier" receptacle than other brands, I had to "adjust" the spades a bit to get a solid contact.
skipper_tim is offline
Old 01-14-2013, 11:12 AM
  #1608
Slotmachine's Avatar
Originally Posted by pword
Anyone knows when this ESC will be back in stock? Site says "product temporary unavailable"...
The pro -a combo is in stock for $199.00
http://www.falconsekido.com/products...sct-pro-series
Slotmachine is offline
Old 01-14-2013, 02:22 PM
  #1609
pword's Avatar
Trader Rating: 30 (100%+)
Yes saw that but i want to keep the cost down now that my motor is still ok. thanks though.
pword is offline
Old 01-14-2013, 03:59 PM
  #1610
rcboy1's Avatar
Hobbywing/ FalconSEKIDO has announced that they are doubling the period the warrenty is in effect. I honestly dont think you will ever need it but it's good insurance.
rcboy1 is offline
Old 01-14-2013, 04:12 PM
  #1611
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
i must say i added a bec (spectrum) and my scte ran awesome with a sctpro..... i did it because i was running a savox servo, so i must say if you are thinking about grabbing one it is a perfect unit for any short course truck... i might run one in a 22sct!!!!
BlackStarRacing is offline
Old 01-14-2013, 04:19 PM
  #1612
lewis110's Avatar
Just make sure you won't have to be in blinky mode as there is no blinky mode with the sct pro lol.
Isn't it funny how spectrum's and savox don't play well together. I have no problems with my SCT pro, Airtronics, savox combination.
lewis110 is offline
Old 01-14-2013, 04:22 PM
  #1613
yeah i have the 4pl from futaba but it seemed this weekend that i had more steering strength to hold on the turns with speed!!!!!
Old 01-14-2013, 04:32 PM
  #1614
What would be a recommendation for a esc running 17.5 blinky offroad?
microracer25 is offline
Old 01-14-2013, 04:41 PM
  #1615
Extreme Stock is a good choice. Light and compact. Smooth and fast. Fits very nicely on the latest buggies like the 22 and DEX210. We do not need to run the fan.
Old 01-14-2013, 04:47 PM
  #1616
Andy63's Avatar
True that! I myself use extreme stock without all punch/turbo stuff for smoother feel. Works great!!
Andy63 is offline
Old 01-14-2013, 05:33 PM
  #1617
TCCustoms's Avatar
got one on my Arrrma buggy running a RevTech 17.5 blinky....Love it
TCCustoms is offline
Old 01-14-2013, 06:27 PM
  #1618
Mowingrass's Avatar
Trader Rating: 19 (100%+)
Hey guys im building a ebuggy for my dad and i was wondering what combo to get because its confuseing on what motar is the best choice im talkin bout the xerun 1/8 combo cause they use the 4--- numbers get the smooth one or the one with the bumps?? Thanks in advance guys and i think i want the 150a for him cause hes new so want somthin pretty bulletproof
Mowingrass is offline
Old 01-14-2013, 07:19 PM
  #1619
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Agreed, You shouldnt need to ues a fan on this esc either in a buggy.
Blitzrockey is offline
Old 01-14-2013, 10:53 PM
  #1620
Brian Miskolczi's Avatar
Trader Rating: 162 (100%+)
MowingGrass- Here is the part number for the combo I would suggest: 81040230 This is the 150A Speed control, 2200kv motor and programing box. If you would like a little less power the 81040220 has the 1800KV motor, with the same as listed above. I would go with the 2200kv.
Brian Miskolczi is offline
