HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree196Likes
Old 12-28-2012, 05:05 AM
  #1501
Suspended
Trader Rating: 440 (99%+)
So does the 150A come with any software? I see on the hobbywing website that the software looks eerily familiar to the Brushlesshobbies.com software I already have. I'm assuming I can just plug these HW escs up to that?
MattP is offline
Old 12-28-2012, 05:28 AM
  #1502
lewis110's Avatar
Brushless hobbies is just a copy of hobbywing. You can run hobbywing software on there esc's also.
lewis110 is offline
Old 12-28-2012, 05:31 AM
  #1503
lewis110's Avatar
Originally Posted by kaneye2
Can anyone confirm that if you've recently purchased an LCD programming box from HW that the firmware is up to date?. If not, how simple is it to download from the site?. I just got a box within the last week, and just wanted to make sure that there was no need to update the firmware before programming my ESC. I'm running the HW SC8 ESC BTW. Thanks in advance.
As long as your program box works with your esc I wouldn't worry about changing it. If you have a V3 then you would need to change the software on the box.
lewis110 is offline
Old 12-28-2012, 06:08 AM
  #1504
So I recently bought a WP SC8 combo that came with a ezrun 3656 motor. When I opened the box, I saw that one of the solder posts on the motor was broken. Is it still ok to use, or do I need to try to get a replacement? Also, I'm completely new at soldering, so that may make a difference too.
Attached Thumbnails HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-motor-1.jpg   HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-motor-2.jpg
Psychotoad is offline
Old 12-28-2012, 06:22 AM
  #1505
BillyT.'s Avatar
I would still use it... But I would hate to wait and get an exchange.
Just make sure you get a good solder joint at the base.
BillyT. is offline
Old 12-28-2012, 06:55 AM
  #1506
d_scientist's Avatar
@psycho, just use it
@Matt, u can programm from the box or connect to ur pc which has the software downloaded.
d_scientist is offline
Old 12-28-2012, 09:06 PM
  #1507
Trader Rating: 53 (100%+)
Does the Justock speedo have reverse?
nv529 is offline
Old 12-28-2012, 11:25 PM
  #1508
Suspended
Ok thanks guys. This is what I bought two of and if I like them I'm going to buy 3 more:
http://www.falconsekido.com/products/xerun-150a-sd
MattP is offline
Old 12-28-2012, 11:29 PM
  #1509
Suspended
I guess Speed Passion, Hobbywing and BHR are all the same because all three work with the same BHR software....
MattP is offline
Old 12-28-2012, 11:31 PM
  #1510
Suspended
It looks like it does according to the tuning chart they show with the speedo:
http://www.falconsekido.com/products...c-esc-for-1-10
MattP is offline
Old 12-29-2012, 02:37 AM
  #1511
darcness's Avatar
I just placed an order for the 4274 1800kv motor on falcon sekido. Does this motor come with the sensor wire or will I need to purchase this separately?
Also I ordered a SCT Pro 120a ESC. Would this come with a sensor wire?
Just making sure so I can be all ready when I get them in.
darcness is offline
Old 12-29-2012, 06:32 AM
  #1512
BillyT.'s Avatar
That combo will run super smooth, cooler and longer unsensored. At least try it unsensored... It will prolly surprise you.
BillyT. is offline
Old 12-29-2012, 06:51 AM
  #1513
lewis110's Avatar
Speed Passion is rebranded Hobbywing built esc. Brushless Hobbies is just a downright copy.
lewis110 is offline
Old 12-29-2012, 07:06 AM
  #1514
rcboy1's Avatar
Pretty much every Hobbywing ESC can be programmed to have reverse. I do not own a Justock ESC but I would be confident in saying it does.
rcboy1 is offline
Old 12-29-2012, 07:53 AM
  #1515
spdrac430's Avatar
Trader Rating: 35 (100%+)
so I can use my speedpassion pc program to change the software in a hobbywing
spdrac430 is offline
