HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 12-25-2012, 09:22 PM
  #1486
d_scientist's Avatar
Originally Posted by Vegatron75
When I'm using a motor and esc that doesn't have solder posts or tabs, I'll just cut the wires to the length I want, then solder the them together.
Less solder joints than bullets and neater.
that sounds like an even better idea except that it is not removable/separateable. Anyway, can you please be ever so kind to provide some pics of ur past/current setups where u solder the cables together?
Many thanks
d_scientist is offline
Old 12-25-2012, 09:24 PM
  #1487
Originally Posted by mosfet
Can modify XERUN 150A FW for support auto detect 4S 5S 6S lipo?
u can set it to autodetect ur lipos. use the set button or the programming card that comes togehter
Old 12-25-2012, 09:48 PM
  #1488
rallyredevo is offline
Old 12-25-2012, 11:22 PM
  #1489
Originally Posted by rallyredevo
I know of no standard technique of soldering wire end-to-end, so I would like to know/see how it was done as well.
try this? I cant access youtube from work yet!
www.youtube.com/watch?v=NlTt1-R3qOQ
Old 12-25-2012, 11:50 PM
  #1490
Trader Rating: 90 (100%+)
Originally Posted by Kevin_M
I have the same setup on my e buggy and have same issue with wires looking all messy. I dont have any suggestions for you but I hope someone can help. Id like to hear as well.
Don't cut the motor wires, you can shorten the ESC wires and put the bullet connector's elsewhere. I also hide the colored wires with expandable sleeving so it don't show the ugly colored cables.
Kuya_Kimo is offline
Old 12-25-2012, 11:54 PM
  #1491
got any pics to share with us?
By the way, does anyone has any idea where I can find the female bullet connectors for xerun 150A esc?
Old 12-26-2012, 08:37 AM
  #1492
BillyT.'s Avatar
Is the ESC wired directly as well? Or are there posts under the shrink wrap? I'll look today
On my current setup, I am running castle 4mm bullets without issue.
Once I finally commit to a motor, and I'm real close, I might hard wire everything.
Also, I have a technique for splicing wire together that doesn't use any solder, but you must use the shrink wrap that has glue in it. It's legit, and won't pull apart.
Just strip the ends, fan out the strands, press the two ends together, then roll the stands inside each other, slide the shrink wrap in and heat it up. You could add solder in there if you really wanted to, or didn't have access tot he right shrink wrap.
BillyT. is offline
Old 12-26-2012, 10:51 AM
  #1493
Vegatron75's Avatar
I do the same as the above here. Except I'll solder the 2 ends together. I've extended the power wires as well.
Uploaded with ImageShack.us
Vegatron75 is offline
Old 12-26-2012, 11:07 AM
  #1494
Theibault's Avatar
Here's a good video on soldering. I don't like splicing, I solder direct to teminals when ever possible. Same process works for adding bullets to wire.
+ YouTube Video
Theibault is offline
Old 12-26-2012, 11:22 AM
  #1495
Old 12-28-2012, 02:06 AM
  #1496
Suspended
Trader Rating: 440 (99%+)
So I'm looking at trying out a HW 1/8 esc for the first time. Which one should I get for 4S running in a buggy or truggy?
I am looking at the 150A pro and the SCT pro 120A.
MattP is offline
Old 12-28-2012, 02:33 AM
  #1497
Default Programming Firmware
Can anyone confirm that if you've recently purchased an LCD programming box from HW that the firmware is up to date?. If not, how simple is it to download from the site?. I just got a box within the last week, and just wanted to make sure that there was no need to update the firmware before programming my ESC. I'm running the HW SC8 ESC BTW. Thanks in advance.
kaneye2 is offline
Old 12-28-2012, 02:49 AM
  #1498
Hi Matt,
THe 150a goes up to 6s! If you wanna save some $$ u can try the 120A. But take my word for it, better be safe and spend a little bit more on the 150A. I did that and did not regret it! Oh, pls bear in mind that the 150A is slightly bulky. You might want to check the dimensions before buying. Cheers
Old 12-28-2012, 03:42 AM
  #1499
Suspended
MattP is offline
Old 12-28-2012, 04:04 AM
  #1500
Suspended
Nevermind I see the blue xerun is a sensored unit so I'm going to go with two of those. This will be my first hw purchase so I hope they serve me well.
MattP is offline
