Charging LiFe's?
Is there a standard out there when it comes to charging/breakin/running LiFe batteries.
I Picked up a turnigy 4500 life. Ive seen some say that Low Voltage Cutoff is not necessary, but others who still use it but just at a lower cutoff than lipos... Same with charging rates, im assuming a 4500 can be charged at 4.5 amps, others say it can be charged at 10, etc.. Just looking for clarification and trying not to ruin a battery lol. |
No cutoff required
Fully charged they will be 3.6v / cell straight off the charger They have a fairly flat discharge curve and power will drop off noticeably well before they are empty (around 2.8v / cell) If you want to set an LVC set it at 2.6v / cell Some believe they should not be deep discharged for the first few cycles, not a bad idea to do it if you dont need the full capacity Manufacturer will list the charge rate for a particular pack If in doubt do it at 1c Even if the manufacturer suggests a 1C charge rate most will handle 2c with a good charger will no ill effects Cheers |
| All times are GMT -7. It is currently 10:29 AM. |
