Help Binding Spektrum Rx and Module via KO Propo Tx
As the title implies...
I have a KO Propo transmitter. I am trying to bind it using a module and Rx from Spektrum I just bought. I bind it and only the steering is working. Any thoughts or troubleshooting you guys can think of? I am running with a MMP ESC. Thanks in advance.. VS |
i don't think its a bind problem since the servo works.
Try putting the esc plug in the steering slot and the servo in the throttle slot. If the servo doesn't work you might have a bad RX. I say this since the servo works that means the esc is sending power to the RX and servo and it could mean that the signal lead is bad in the rx. |
