Best 10Amp Lipo Charger
Just wondering what everyones opinion on the best Lipo charger is. I need one that can do 10amps or more. Doesnt need to have an internal balancer or only do lipos. I have been doing a little research but wondered what actual owners opinions are. Not looking to start a war here; just looking for a little info and opinions. Thanks in advance.
I hope you're interested in a DC powered charger. Highest I've seen in a AC/Dc is 8amps.
My advice would be the iCharger 106b, its has a 10amp max charge rate and 250watts of charger output power and for ~$100 its a pretty good deal. If you need higher charge rates, iChargers are available with 20 and 30amp max charge rates.
Venom has a 10 amp, 200w unit for around $60 shipped:
http://www.venom-group.com/itemdesc.asp?ic=0665
This i-charger and venom (or any of it's clones) are decent 10 amp chargers , so is the TC 1030 Checkpoint.
iCharger without question.
Agreed....3010B for 30A!!
Specifications:
• Maximum charge power capacity : 1000W (@ input voltage > 23V, 500W @ 12V)
• Charge current range : 0.05–30.0A
• Discharge current range : 0.05–30.0A
• Input voltage range : 4.5–38.0V DC
• Maximum discharge power capacity : 80W
• Maximum regenerative disharge : 1000W
• Maximum external discharge power capacity : 1200W @ 40V/30A
• Current drain for balancing : <500mA
• Balance accuracy : <10mV
• LiPo/LiIo/LiFe : 1 – 10 series (In non-balanced mode, up to 12S LiFe)
• NiCd/NiMH battery cell count : 1–25 series
• Pb battery cell count : 1–18 series (2–36V)
• Log files storage : 16 Mbit (36 hours)
• Battery setup memories : 10
• Intelligent temperature control : Yes
• PC Connect : USB port
• Weight : 750 g
• Dimensions (LxWxD) : 143x123x46 mm
Specifications:
• Weight : 750 g
If you don't need the 10s capability of the iCharger 3010B then you can get the 6s version for a bit less. Also note that the i-charger/Venom chargers are not the same manufacturer as the Junsi iChargers. The Junsi iChargers are considered to be the best "Chinese" chargers.
