Power Supply Question
Im a complete noob when it comes to voltage questions.
What I'm trying to accomplish is only having one power supply for 2 chargers. I am using these chargers http://www.hobbyking.com/hobbyking/s...dProduct=15164 I want to be able to charge at least (1) 4s at 5a. Is there anything out there around the $50 mark that will be what I am looking for? |
yes, I think that power supply can supply the two chargers that you have to charge 4S batteries on each.
25Amp power supply should have enough juice to power the two chargers... |
You only want to run one charger at a time or both? Those are 80watt chargers so to run one at full power it'd take ~100watt power supply(chargers are typically assumed to be 80% efficient). To run both, you'd need ~225watt power supply.
Here's one that will do either and its $70 - http://www.progressiverc.com/index.p...er-supply.html Here's a PS that would run just one charger at a time - http://www.amainhobbies.com/product_...-138V-10A-130W And a word about your wanting to charge a 4S at 5amps - that requires 84watts (16.8v x 5a = 84watts). Your charger is only 80watts, it will get close to 5amps, but as the voltage of the charging lipo gets to 16.8v, it'll only be charging at a little over 4.7amps. |
Checkout the following tutorial about using an HP server power supply for RC use. Very simple and cheap. You can get the power supply on ebay for $20 or less shipped.
HP 47amp 12v PS tutorial: http://sites.google.com/site/tjinguy...projects/HP47A |
I found this one, but doesnt give to many specs for me to reference to your post. Will this be close to what I am looking for?
http://www.hhvastore.com/index.php?productID=51611
Originally Posted by Duster_360
(Post 8955036)
Here's one that will do either and its $70 - http://www.progressiverc.com/index.p...er-supply.html Here's a PS that would run just one charger at a time - http://www.amainhobbies.com/product_...-138V-10A-130W And a word about your wanting to charge a 4S at 5amps - that requires 84watts (16.8v x 5a = 84watts). Your charger is only 80watts, it will get close to 5amps, but as the voltage of the charging lipo gets to 16.8v, it'll only be charging at a little over 4.7amps. Thanks for that explaniation.
Originally Posted by kcobra
(Post 8955307)
Awesome PS for the size and price, I cant justify a 10lb 20Amp+ brick when traveling.
http://www.amainhobbies.com/product_...n-Power-Supply |
| All times are GMT -7. It is currently 09:20 PM. |
