-   -   types of radios + 2.4 modual speed response ? (https://www.rctech.net/forum/radio-electronics/496189-types-radios-2-4-modual-speed-response.html)
reptile 03-25-2011 05:41 PM
Have a good ? for radios that you can put in a 2.4 modual does the type of radio matter for speed response? or is your response only as good as the 2.4 plug in modual is?
Another words say i am using a old FM ko propo mars radio with the new spektrum 2.4 pro modual would the response be the same as if i used the same modual in a ko propo mars R ...does the radio it's self effect speed response?
THANKS
crusey_aus 03-25-2011 05:48 PM
Decent 2.4g radio sets can be found for around $100
I wouldnt bother trying to upgrade your old set with a module that is likely to cost you just as much
Cheers
reptile 03-25-2011 07:12 PM
Cheers
Hi that's not my ? you mis understood my point?
Derry 03-25-2011 08:44 PM
THANKS
I believe it is only as fast as the modual...
gotaslash4x4 03-27-2011 07:06 PM
new radio
Has any one seen the new "RadioPost" radio's? If so where, and how much are they?
