Help!! Throttle when I turn wheels???
Ok, so I am getting back into rc's. It's been 20 years since I used to race my RC-10 and things have changed!!!
This is what I've got... Jammin SCRT10 Mamba Max Pro Esc 5.5t 550 Novak Ballistic Motor Savox SC1256tg digital servo Flysky FS-GT3B Radio control Venom 50c 5000mah 2s lipo Now here's my problem. I've calibrated the transmitter to the car and everything works except when I go to turn the wheels, both the wheels turn and I get full throttle. I do get forward and reverse from the trigger. The motor comes on only at certain points when I turn the wheels. I have no idea what to calibrate here. Is it the ESC, transmitter, or reciever? Or something else? I am at a loss here. HELP ME!! :confused: |
My guess would be a bec related issue, common prolem many of us encounter
Reciever gets power from the bec in the ESC Your servo is drawing too much power and causing the reciever to drop out, happens when bec is not up to the task May be easily fixed with a glitch buster capacitor Worst case scenario you may need to install an external bec ($30 or so) Cheers |
Just to eliminate some obvious, make sure steering servo is plugged into channel 1, ESC in channel 2
The 1256 servo shouldnt be too much for the BEC its not super fast like the 1257 so it shouldnt have huge spikes. The reason i say this is i have 1257 and 1258 servos, i run MMP's and Tekin RS's. The RS BEC has no trouble pulling any of these servos, but when i put a 1257 on the MMP i need to run a cap. No issues out of the 1258. Odd rite? But thats how it is and I need to run a cap when using a MMP/1257 setup. Still if it is the servo pulling too much i would look into a receiver capacitor you can get for like 5 bucks over spending 30 on an external BEC. I really like the MMP, great tunability, smooth, and handles lots of power. Its only downfall is it's weak BEC circuit. |
@ gizmo..what cap value are you using? i will be using a 1257 for throttle and a 1256 for steering... on a sanwa 451r... what cap should i use?
Yea. Servo is in ch 1 and ESC is in ch 2.
How does the cap install? |
Originally Posted by BOOTZ
(Post 8809212)
Make sure your battery(car bat.) is charged, if it's not the servo can pull down the voltage enough to cause a problem.
Also, make sure your steering end point is not set too far. If the servo is trying to go past the point where the steering linkages can go, it will demand mega amps that can also pull down the battery voltage. |
Originally Posted by etivac13
(Post 8809173)
I didnt need the cap with the nitro, just the electric 1/10 that i run. It wouldnt hurt to run one though as they cant hurt anything really... I was running pretty similar servos in nitro truggy 1256/1258 str/thr. Good stuff ;) |
I posted a similar question a day before this one came on as I am having the same issues and received the same response. Glad you guys know what's going on, because I had no idea as well.
I put the capacitor in and fixed everything!!!
This thing is a BEAST!! :D |
| All times are GMT -7. It is currently 02:32 AM. |
