-   -   Servos blowing (https://www.rctech.net/forum/radio-electronics/491553-servos-blowing.html)
hdcruzer 03-12-2011 07:47 PM
Servos blowing
Can a bad receiver blow out servos. Ive had a terrible problem with servos blowing lately, just my throttle, been through 3 in the las 4 mos. And no there not not cheapies. There all 110.00 plus servos. Yes I know how to align and set my epa......
aussies1129 03-12-2011 08:10 PM
yes a receiver controls the servos so if you dont have your end points and steering throw setup correctly you will burn out a servo very easily:nod:
hdcruzer 03-12-2011 08:13 PM
Like I said, I know how to set my end points. Can the receiver itself overload a servo and cause the motor to burn up.........
stretch76 03-31-2011 01:13 AM
Ive got the same issue, both my servos went last night at the same time, without operating them so EPA never was an issue. By the way I checked both servos were working before I installed them into my new car, after the installation neither work. Have tried a spare servo, this works fine. Any help or advice world be appreciated. By the way its a spektrum reciever.
crusey_aus 03-31-2011 02:27 AM
What are you using as a power source for the RX and Servo ?
Cheers
stretch76 03-31-2011 02:39 AM
I'm using 6v hump packs
Duster_360 03-31-2011 04:59 AM
Check the voltage coming from the rcvr.
The answer to your ques is yes, a bad rcvr can cause servos to go bad.
