Speed Passion Thread
#151
So what base setup would you go for with a 7.5 for a cougar SV on Uk astro track?
Shouldn't have order the 6.5 for 4wd etc!
#152
hey guys im running a gt 2.0 lpf in my 22 with a 13.5 orion vortex. Ive gone up from the recommended 26t pinion to a 28t pinion and Im still not getting enough straight line speed or punch. Its good through the turns though. Im not using the LCD programmer and any special software just the basic program card. I did some bench tests and saw more power come out when the I increased the timing advance. From 0 to level 5 not much difference but level 6 and up, significantly more power. What I want to know is should I go back down to the 26t pinion which is whats recommended on the 22 gear chart or stick with the 28t. I just dont want to deal with creating too much heat. Any ideas guys?
Also Im running a mild drive profile, I believe its the "smooth" profile which is level 2 on the card. Should I try a more aggressive throttle profile before I do timing advance? Thing is I like the smoothness of the first 2 profiles. Im new to this esc guys help is appreciated.
#153
What are temps on motor now? The LPF GT has 205 mod loaded. Where is you AMTS set at? What about physical timing on motor? Turn it all the way up since your not running boost. Gear the motor until you reach top seed about 3/4 down the longest straight on the track. This should still give you plenty of rip on the infield.
#154
#156
All right boys, LCD box upgraded, 0323Stock loaded on my GT 2.0 LPF. Time to read up on the new software and play around LOL. Think I'll leave 205Mod on my 2.0 Pro until I get the hang of the new software. BTW, been meanign to mention. If you go the setups on the SP website and choose 2wd Offroad, it gives you one page of setups, and shows a clickable icon for a 2nd page of setups at the bottom. But, if you click that icon, it links you to 4wd Stock TC, not a 2nd page of 2wd Offroad.
#157
Ill tell u this... so far the SP/Orion combo is super smooth. And should I def increase motor timing right away or just go the esc route first?
#158
gotcha, should I go back down in gearing? The gear chart calls for a 26t with the stock spur. Currently at 28. Maybe I should do the recommended gearing and mess with the AMTS timing from there?
#160
I'm running the SC Master combo in my SC10 and have a thermogun. What should I be aiming at? The endcap or the can?
Either way I haven't broken 140 degrees running in AZ with 22/84 gearing and a little timing. It's been a couple months now of twice a week racing and have been really happy with this combo.
I'm hoping to get an SC10 4x4 soon and after looking at Novak, Tekin, LRP and CC, I think I'm going with the GT 2.1 ESC. I love the portable program card for quick changes and the constant updates to the firmware and support here.
Keep up the good work guys!
#161
#162
Any 13.5 2wd setups to suggest? Small track carpet. keeping the front end down can be tricky.
Looking for a mild and wild but drivable suggestion to start with.
I had the old stock software installed with:
ddrs VI
7 amts
SC boost off
rpm delay 5000
sc full throttle .4sec
SC punch -3
It was not as snappy as i wanted on the straight but when i used boost i would get a light front end if i over juiced the trigger. (my trigger finger is heavy so i have to dial out to compensate for its girth)
ddrs VI
7 amts
SC boost off
rpm delay 5000
SC punch -3
#163
JP Richards has max timing on motor and ESC both...amd he was running MOD. Your 13.5 must be full TIMING in order to get it going. But don't just copy what I am saying cause you are running Orion motor, which I am not familiar with...but, at least try 1/2 of the full range of timing on your Orion.
http://www.speedpassion.net/uploadfi...IndoorClay.pdf
#164
ddrs VI
7 amts
SC boost off
rpm delay 5000
SC punch -3
ddrs VI
7 amts
SC boost off
rpm delay 5000
SC punch -3
http://www.speedpassion.net/uploadfi...20Mike%20K.jpg
#165
Speed Passion USA direct sale website is UP AND RUNNING, AGAIN
http://www.speedpassion.net/us/index.asp
Check it out, most of the hot selling item are back instock and ready for 3-4 days local USA shipping, that advantage of that....we have sold out like 40% of the inventory so don't wait, it you sees it, buy it now...
Mark
