Speed Passion Thread
#1501
Having issues with my reventon s. Ran it 3 times so far. On medium to hard landings/flips/wrecks it sort of shuts off. It's still lit up and lights change as i use the throttle it just doesn't send power to the motor. And then the second issue is no bottom end. If i a stopped on a jump and went to take off again it cogs and may not even make it back over the jump. And on the take off it shutters just barely at first but that has gotten progressively worse. Coming around a tight corner coming out it does it.
#1502
Can anyone tell me where does the light blink on the case of the gt 2.0 when it's in 508 no timing I don't see a light I upgraded firmware twice recalibrated esc all I get is solid green when I squeeze full throttle is the sticker blocking the light?
#1503
From what my drivers told me, they were never use 205g anymore because it is slow.....they are all running 428STOCK with boost and supercharger along with the 4x4 used motor. I have seen some using it on NOVAK and some on TEKIN (but I have not seen that in person)....some of the drivers are running the prototype Speed Passion BLAZE 4x4 SCT motor and actually they are using it at the up coming Futaba Race that host at Leisure Hour Raceway this weekend.
The BLAZE should be release around end of August.....as well as the 1/8th version of the BLAZE motor.
#1505
Hey Guys,
I just received the above mentioned ESC by fed ex today and it comes with a programming box. Do I need anything else to get me going? I am going to give this esc a try with a Thunder Power 5.0 550 motor in my Durango DESC 410. I'm currently using a Tekin RX 8 with a 4000 4 pole motor and appreciate any feedback you can give me.
Thanks,
Thanks,
If you simply just want to try it, you can run the GT2 PRO now with the 205G and use the included programmer box and adjust the parameter. But I know most ppl who use the GT2 on 4x4 SCT are running boost so you might be behind on the speed...simply because you are running a mild software compare to others who run the boost/turbo software...
Get the LCD box and take advantage of the boost software.
#1506
#1508
I have the SAII 1/8 scale esc and I've tried everything I could to turn off overheat protection and it just won't. I've used most of the speed passion software versions and even the HobbyWing software to try and disable it, but the option just stays locked (button greyed out) I was wondering if any of you knew something I didn't or maybe there's something I've over looked. I even tried setting it using the program button on the on off switch of the esc.. Any help is appreciated and thanks in advance
#1509
#1511
Thanks Solara. I've also had a new problem come up just today with the SAII. It runs for about 5 mins and then just stops with solid red light. Nothing works while it's in this state, but if I unhook the battery and power it up again it works fine. Any ideas?
#1515
I would like to know...what makes the PRO4 motor any different then other motors...? Because it is 4 poles and 550..? They gear differently and the timing adjustment has to be different...?
http://www.speedpassion.net/inc/down...20Walt%20G.jpg
