-   -   Need help hyperion 615i Duo3 (https://www.rctech.net/forum/radio-electronics/490058-need-help-hyperion-615i-duo3.html)
SuperEk4 03-08-2011 07:33 AM
i have a hyperion 615i duo3 which cant charge 2s. Dunno why it just show error connection halfway charging. I tried all 2s lipo & all cant.
it has no problem with 3s & above.
I tried upgrading the software but it doesn't help. Can Anyone help? thxs!
SuperEk4 03-08-2011 04:37 PM
No one knows?
Dave H 03-08-2011 05:40 PM
No.
But hey, when did that become a posting rule… ;):smile:
Are you saying it starts charging, then quits in the middle of the charge? Are you always using the same 2S harness? Any wiring or connections heating up? Try wiggling the wires to maybe locate any possible weakness.
Same on both ports? Tried without balancing? (Forget the details, but aren’t some of the Hyperion balance wiring orders different than other brands?)
SuperEk4 03-08-2011 05:54 PM
Originally Posted by Dave H (Post 8769841)
No.
Lol, it's not a rule but I need my charger sold but I need to solve this problem:)
Thx for all the options. I will try them out tonite.
thormotox 03-11-2011 10:02 PM
I'm having a similar problem. Got mine yesterday and I will not fully charge a 2s pack.
SuperEk4 03-11-2011 10:38 PM
When I change my balancing tab problem solved
thormotox 03-17-2011 10:14 PM
mine does it on both tabs.
DavidR 03-17-2011 10:29 PM
Sounds to me like you guys might be using the wrong balancing boards.
Some of the balancing taps will plug into the wrong board... It'll SEEM like you're using the correct board, but you're really not.
I did the same thing once with a 3S battery... would charge about 3/4 of the way then when the charger went to actually start balancing it figured out something wasn't right.
