Did I ruin my new LIPO? :(
So I got a brand new BLUE 3000mAH 20c 4s battery for my starter box today. I went to change the plugs from the stock ones to bullet connectors. When I took off the plug the two wires touched and arched. It made a small spark but nothing to bad. Now my charger wont recognize it (Connection Break), and when I plug it into the box there is no power.
Can any battery experts help me out here? I know I did this once before with a LIPO for my mini and it didn't work for a while, then one day did. So idk. Help please! lol Thanks.
R/C Tech Elite Member
My bet is that you ended up melting one of the solder tabs in the pack itself...
If thats the case you MAY be able to fix it if you're careful... But if you don't know what you're doing I wouldn't mess with it.
As somebody else stated.. and you're now aware.. Don't cut both sides of a plug off at once.. Cut one, solder to new connector, cut the other, solder it.
Good luck though!
Good luck though!
you may have shorted one of the balancing wires. Don't make it charge if it doesn't recognize it!
cut the plastic off to uncover the wires, make sure they're all connected. If you see a wire that isn't... solder it.
also look for "bridging," where two wires are touching.
I've fixed two LiPo batteries, not scary.
Thanks for the replies. I should have known to only do one at a time, I wasn't really thinking i guess
I'll try the NIMH mode. With a fire extinguisher on hand. The pack doesn't appear to be puffed or damaged in any way. I looked inside the wrap at the connections and see no burns or broken connections either.
Are there any precautions or special steps to take when charging in NIMH mode?
Thanks again!
Thanks again!
Good luck though!
Good luck though!
