brushless combo question
Hey all !
I am shopping for Brushless set up for my boat. this is what i have come up with . the jet drive unit im installing has a max RPM 20000 So, 2700KV @ 7.4v = 19980 RPM I will run 2 1500mAh 7.4v 25c 4s in parallell So, if discharge A=(mAh)/1000 x (c) 3000/1000 = 3x25 =75A do i need a 75A or higher rated ESC ? i am looking at a 35A ESC With a 5v 1.5A BEC Will this work with a 2.4 ghz receiver and digital servo? or do i need a BEC with 6V 1.5A. Here are the items: Motor KV2700 Brushless in runner RC Motor for RC boat(WaterCooled) Rotational Speed 2700Kv (rpm/v) Input Voltage 7.4v- 14.8v Batteries 2, 7.4 v 1500 mAh Lipo4s 25c, run in parallel, @ 3000 mAh output. lipo Size:71.4mm x 35.5mm x 19.2mm Battery Capacity:1500mAh Battery Voltage:7.4v ESC 35A brushless boat esc with bec 6v/1.5A ,built in cooling jacket. Continuous Current:35A; Burst Current:190A; Working Battery Types:4-12 cells 2.4 ghz 2 channel transmitter/receiver servo speed 0.14 /torque 75 oz/in @ 6V Size:40.8x20.1x38mm Weight:52g Operating voltage:4.8V~6.0V Any advice ? Thanks in advance |
Doesnt quite work like that mate
Your motor will have two current ratings (constant / continuous and burst) Your Batteries and ESC need to be able to handle these rates Ideally if your motor bursts to 50 amps you would use batteries and an ESC capable of 50 amps continuous Cheers |
| All times are GMT -7. It is currently 10:00 PM. |
