TEAM POWERS NEW PLUTONIUM MOTORS
#511
I am looking at this post to get some feedback from TP 21.5 owners!
what is your recomendation for a 40x80 carpet track , Fdr and timing info are welcomed!
I have it stock for now but 12.3 rotor is waiting for testing! (Usgt class)
my first run was impresive , full timed with 3.96 fdr but it reach 170 deg!
#512
is that the actinium motor v1? what size rotor does it come with?
#513
#519
Has anyone used the end bell that gives more timing and if so were did you get it from?
#520
Wanted to say THANKS for the advice, I was running a Trackstar 21.5 with its timing onthe last mark, and a cheap Yeah fan. 140-150*F, 3.94 FDR Installed the Actinium 21.5, cranked timing to the last mark, added a R1 Wurks fan and it got up to 128*F measured on top of the motor, 155*F measured underneath. 4.14 FDR. Oh, and it hauled A$$, pulled so hard I it was spinning out exiting the corners. Overshot some braking zones because i'm not used to carrying so much speed into a turn. Had to re-learn driving with this much power.
This is a great motor
. I think I'll back the timing down one tick to cool it down and get some midrange.
#525
I have the Actinium 21.5 at max timing (4) and 4.0 FDR running in USGT on a large outdoor parking lot track. As always awesome but as the outside temperatures are starting to get warmer here in TX so is the motor (near 150F last race when it was ~90F outside). I'm trying not to use a fan as the car is already heavy because of the 1400 gram USGT weight limit here. Anybody have any luck with this motor using less timing and more gear or do I need to just bite the bullet and put the fan in the car?
