-   -   Rx8 and ballistic 550 (https://www.rctech.net/forum/radio-electronics/484657-rx8-ballistic-550-a.html)
shortcut 02-21-2011 03:36 PM
Will the ballistic 550 run on the rx8 ?
NovakTwo 02-22-2011 08:39 AM
How are you planning to use these?
Which Ballistic 550 wind and how many cells?
TeamNovak Ballistic 550s
shortcut 02-22-2011 09:16 AM
2s, 4x4 sct.
NovakTwo 02-22-2011 11:00 AM
Recommended high performance, low RDS-on (0.00040ohm), racing controllers for Ballistic 550s in 4x4 SCTs on 2S
Current Novak ESCs
GTB 2
Affordable, new on-board programming options, 4.5T/550 limit (3.5T/540)
Havoc Pro SC
On-board programming, including timing adjustments, 4.5T/550 limit (3.5T/540)
Kinetic Spec
PC programmable (NL), up-dateable, all new programming, low profile, 5.5T/550 limit (8.5T/540)
Kinetic 2S
PC programmable (NL), up-dateable, all new programming, 4.5T/550 limit (3.5T/540)
Older Novak ESCs
GTB
Ballistic 550 4.5T (3.5T/540)
Havoc Pro
SLYDR
We have no data regarding RX8 compatibility/performance with our Ballistic 550 motors.
shortcut 02-22-2011 03:43 PM
Thanks for the reply, I didn't know I could run a ballistic 550 with my older GTB, now I do.
NovakTwo 02-22-2011 04:20 PM
As long as you stick with 2S, all these escs work great. Sometimes, you can get a good deal on the older (discontinued) escs.
jsamarin 02-22-2011 05:42 PM
Hey man,
The rx8 is probably one of the best options on the market to run a 550 motor, you wouldn't be sorry if you bought one!
shortcut 02-22-2011 08:02 PM
Originally Posted by jsamarin (Post 8694987)
Hey man,
I just picked up an rx8, I can pick up a ballistic 550 4.5 for a good price local and wanted to make sure I was able to run the motor.
