Radio Question - Is this possible with 2.4Ghz? >
Old 02-20-2011, 11:27 AM
Default Radio Question - Is this possible with 2.4Ghz?
Hi guys,
I was wondering if this is possible:
I want to have 10 cars all with their individual receiver.
I also want to have 2 radios, and I want to be able to control all 10 cars with BOTH radios, and as many as 2 cars simultaneously.
ie, I want to take car A and Car B for a spin, and be able to control one with one radio and the other with the other radio, and then switch off car B and take car C and control it with 1 of the radios.
I hope that makes sense.
Anyway, can this be made to work?
Spetz is offline
Old 02-20-2011, 02:07 PM
Usually a reciever can only be bound to 1 transmitter at a time
Systems like the Traxxas "Link" may allow you to do what you are asking
Cheers
crusey_aus is offline
Old 02-20-2011, 08:21 PM
snoopyrc's Avatar
what he just said I think is true but that does not mean that you cant take Car B and bind it to radio A and then later bind it to radio B. And you can have model memory for 10+ cars on lots of new radios anymore. So what you want is almost possible with the inconvenience that if you want to use a transmitter differrent than you usually do then you will have to go through the bind procedure first.
snoopyrc is offline
Old 02-21-2011, 12:40 AM
How hard is the bind process?
And, what about many receivers to 1 transmitter, this is also possible right?
The reason I ask to make things simpler is I have many cars, and sometimes me and my brother would go race, so I would like us to each have a receiver and then choose whichever car we want and go race
Spetz is offline
Old 02-21-2011, 12:49 AM
You will see radios quoted as having a number of model memories
10 model memory means 10 recievers / cars
Usually the bind process requires a small plug to be inserted into the reciever, then a button pressed on the transmitter, pretty simple
Cheers
Old 02-21-2011, 06:22 AM
Trader Rating: 21 (100%+)
I use a 3PK and with its 10model memory and removeable Campac module, I can manage 20diff RCs. I use a 2nd radio, but use it to run 10 different RCs.
This lets me run diff radio setups (diff modes of FM, or 2.4) depending on the car. I might have to switch modules in the controller, but it only takes a few seconds.
Duster_360 is offline
Old 02-22-2011, 11:16 AM
Thanks guys,
And, when buying a transmitter and a receiver, will any two work or is there something specific that I need to look at?
Spetz is offline
Old 02-22-2011, 06:57 PM
AM - most should work with the other brands. FM 75MHZ has a pecularity and some will not work together due to phase shift differences, the 27Mhz FMs don't have this. Radios that use crystals seem to require a matched set - TX and rcvr crystals made by the same manufacturer, I've tried unsuccessfully to mix brands of crystals.
2.4ghz is similar, the diff brands do not generally work together, there's even some conflicts within brands.
Old 02-23-2011, 12:43 AM
So when buying a 2.4Ghz radio, what receivers do I buy to control multiple cars?
Spetz is offline
Old 02-23-2011, 01:18 AM
I know you can control many cars with just one transmitter and one receiver per car.
I did it with my Tactic TTX240 radio, controlled 2 cars at the same timeusing only 1 transmitter.
I don't think you would be able to switch between radios in each car without re-binding the receiver in that car to match the transmitter, that would just be a waste of time and effort unless you have 2 receivers in the car labelled A and B, and you just switch between the two depending on the radio you are using. That's the only way I see it working the way you want it to.
DJ_Shakespear is offline
Old 02-23-2011, 08:51 PM
snoopyrc's Avatar
I dont think you intend to control two cars at the same time so I will give you a more simple answer. Stay with the same brand. Thats where the compatability issues mostly lay.
If you use FrSky Transmitter on 2.4 then use FrSky receivers. If you buy a Futaba 2.4 Faast then use Futaba Faast receivers. FrSky makes junky looking transmitters but their receivers are dirt cheap. So you could put one in each of your cars and also you could have a memory setting for each car. So if you have been racing with your SCT and then you want to take the transmitter and drive your drift car with it, just change the memory to your drift car, bind it and there you go.
snoopyrc is offline
Old 02-24-2011, 12:52 AM
LarryMann is offline
