Orca ESC/Motor Stuttering at low throttle
I recently purchased a Orca VRITRA VTC ESC and Orca 6.5T brushless sensored motor. I have installed today, and i'm having some problems.
Basically, the ESC either stutters or cuts out then applying any throttle. If i give my RC car a little push to get it moving i will get power stuttering at low throttle and then it smooths out about 1/3 throttle is then ok right up to full.
Every time the motor becomes stationary it cuts out unless you get the motor spinning (by pushing) first.
When i first installed, i ran around living room to test at low throttle, it was fine and perfectly smooth. Only after about 3 minutes of usage outdoors at higher speed the problem has come into effect and wont go away.
- Ive tried resetting the ESC using the startup/setup procedure to no avail.
- Ive ensured my lipo battery is fully charged and securely connected via deans plug. All soldering clean and connected.
- During the first tentative run outdoors, i have not maxed out the ESC or motor in any way.
- Ive checked the sensor wires and tried a different sensor wire.
- Ive tried different parameters on the program card.
Could this be a faulty ESC or motor? Perhaps a sensor issue?
Any advice/support would be appreciated. The Orca website provides no support other than manual (which doesn't fix this fault). Im getting worried as i payed a lot for this set-up and im not satisfied its performing correctly. Also, i got the ESC and motor separately over a few months in between - and the manufacturers warranty is only 30 days! So i could stand to lose out big time if this is a faulty hardware...
Thanks.
Thanks.
Hi I am not surprised that you are not getting a respond here. Not many people are aware of this thread. Anyway may I know where you bought the set from? If you could provide more details I should be able to assist you further thanks
All sorted now.
Hi.
I returned the ESC to Answer RC (a UK supplier) and they found a fault with the ESC sensor board. I was issued a replacement in a prompt response.
New ESC running well so far. Thanks for your offer to help anyway!
Demus01.
Demus01.
I'm having the same problem with my new set.
Haven even ran on my car and its having same prob as urs.
I sent back to local supplier but no prompt response like urs..
