Soldering Iron Hakko FX 901??? >
Old 02-19-2011, 07:42 AM
Trader Rating: 98 (100%+)
Default Soldering Iron Hakko FX 901???
I have a Hakko 936 for my home setup that has been a great iron, but I want a more portable just in case iron. Anyone use one of these?
http://www.applefritter.com/node/10572
http://www.frys.com/product/4302455
dan-o is offline
Old 11-24-2013, 11:19 AM
juicemouse's Avatar
I'm also interested in reviews of the FX-901
juicemouse is offline
Old 11-24-2013, 05:41 PM
Super Moderator
Don't have any actual experience, but is that tip large enough to maintain heat for typical RC stuff?
Dave H is offline
Old 11-24-2013, 06:53 PM
ThePanda's Avatar
Trader Rating: 67 (100%+)
on the website page for that iron, they show it right next to a rc truck (looking like its in the process of soldering) I assume you can get tips to use with it as well.
- from the website.
ThePanda is offline
Old 11-24-2013, 07:40 PM
Super Moderator
I noticed that, but oddly enough they don't show that model on their RC Hobby page. Don't know. Quite a few thread views, I now notice over a couple years, apparently few do.
Dave H is offline
Old 11-24-2013, 08:04 PM
RCmayor's Avatar
600 degrees isn't hot enough with the wire sizes we use. The wires absorb the heat so rapidly the joint doesn't get the right amount of heat. I use the blue hakko station that looks like an old radio and I don't get the solder joints that I like until I run it at about 800 degrees. Sure you can leave the 600 degree tip on the joint forever but that heats the electronics up for too long and that isn't good. I like to be able to be on and off the connection in about 5 seconds...
For smaller 16gauge to 24gauge wire it would be fine.
RCmayor is offline
Old 11-25-2013, 04:47 PM
HBRob's Avatar
Trader Rating: 61 (100%+)
I use Weller PSI100K butane. I actually use it now more than my Hakko station, its just easier and I think actually gets hotter.
Link
http://www.amazon.com/PSI100K-Super-...ef=pd_sim_hi_2
HBRob is offline
Old 11-25-2013, 05:51 PM
tpczx6's Avatar
if you are ok with a cord try this one
http://www.testequipmentdepot.com/ha...s/fx601-02.htm
tpczx6 is offline
