1 transmitter, 2 cars/receivers...is it possible?
Hey everyone,
so I'm kinda new to this, but I was wondering if it's possible to use 1 transmitter to run 2 cars without having to bind everytime? Obviously not at the same time.
I don't have a radio yet but I'm thinking of the Futaba 4pl. So can this radio do that? Thanks.
Yes
40-model memory with 10-character model naming
you could purchase 40 receivers and run each car off that one transmitter.
I use the Spectrum DX3R pro, 4 cars, 1 transmitter
Awesome...thanks for the response.
One more question, do I need a voltage regulator for non-high voltage servos if I'm running an electric off-road RC?
look into the spektrum DX3S for up to 10 model settings in memory. Lovely controller and has telemetry built in. Comes in a package with 2 receivers, one of which supports telemetry and has 3 different sensors for temperatures and rpm.
as for the servos, it depends on how your ESC really. Some ESC are able to regulate the volts sent to the receiver/servos while others don't. Find out if your ESC supports that and you can go from there.
No. The BEC/battery eliminator circuit in the ESC provides that service. Most ESCs provide around 5 to 6 volts to the receiver and servo, a spec should be listed in the manual, web site etc.
