How to increase radio distance? >
Old 02-01-2011, 09:03 AM
Default How to increase radio distance?
I have a Nitro RC truck. I have the budget for gadget. I only need the how-to. On youtube, a person increased his radio distance to 1,1 miles and drove his RC while watching through a Wireless camera on a screen at home. http://www.youtube.com/watch?v=pO0o1l0B060
First off, how do I make the increase available distance between the truck and the radio? (In the video description he mentions that he had the "transmiter antenna on [his] roof").
Second off, How can I modify a Wireless camera I would install on my truck to be able to send video signal as far as 1,1 miles like in the video?
Thanks.
helgso is offline
Old 02-01-2011, 12:41 PM
whitrzac's Avatar
Trader Rating: 96 (100%+)
A. what he did to modify the range was probably illegal(FCC things)
B. check out hobbycity.com for FPV camaras+transmitters
EDIT: didn't see that you were in Iceland, I would defiantly check with the local authorities/airport on the max output of an RF single
whitrzac is offline
Old 02-01-2011, 01:26 PM
rangerjkb's Avatar
Trader Rating: 41 (100%+)
It's not leagal and if it causes an incedent you would be held responsible...wouldn't want to go there.
rangerjkb is offline
Old 02-02-2011, 07:38 AM
I'll check the maximum allowed RF output signal in Iceland.
In the meantime, I found this 2,4 GHz system and a user says it can last at least 2 miles. ( http://hobbycity.com/hobbyking/store...dProduct=13437 ) How does this work? I buy it, install the camera and the transmitter on my truck, the transmitter sends signal to my reciever which I can plug into a TV, or a PC with a TV-card?
How about power for the camera? Will I have to buy a special battery or what?
helgso is offline
Old 02-02-2011, 08:34 AM
whitrzac's Avatar
that would be my guess...
like I said, it is more than likely illegal to use...
whitrzac is offline
Old 02-02-2011, 09:03 AM
If it is illegal, explain this. A person on youtube that runs the site www.rcexplorer.se is often flying his aircraft a very long distance.
Check this video: http://www.youtube.com/watch?v=iI_UKiFqRsA
Is this illegal?
helgso is offline
Old 02-02-2011, 11:32 AM
whitrzac's Avatar
its not the range, that is the issue, it is the power output and weather or not you need a license to use it...
whitrzac is offline
Old 02-02-2011, 11:53 AM
at a right angle, from where I would point iti. It now works much better... not as if I was in the same room, mind you
jolf.poder is offline
Old 02-02-2011, 12:44 PM
Great, where can I get long ranged cameras? =)
Ohh and also, it's legal to buy a good radio right? Some expensive radios can supply a long distance?
helgso is offline
