-   -   tekin mode question (https://www.rctech.net/forum/radio-electronics/477538-tekin-mode-question.html)
forrestboy 02-01-2011 08:01 AM
tekin mode question
How do i get my rs speed controller in the so called "blinky" mode using my hot wire and i am on version 208
thanks brandon
Axo24 02-01-2011 12:28 PM
Good timing(well,sorta..lol)....I was just trying to figure that out too today. I'm using 212 software,but its probably the same....Under the "setup" tab,take your "timing profile" all the way down to 1. Number 1 is "spec" mode and you'll notice that your "timing" tab has nothing at all in it after doing this. Plus leds 3 and 5 will blink with my 212 anyway. I'm not sure if this applies with you 208 software. Maybe just your third led may blink...not sure,but it will be one of those two. Some will blink while at neutral,lol. Try it out.....let me know if it works for you....
AreCee 02-01-2011 05:26 PM
You need to update your firmware to 212 to get the spec mode, it's not available in 208.
blktransam 02-02-2011 12:49 PM
yes you have to update to the vegas 212 software...then you just set it to throttle profile #1 eighter by using your hot wire or doing it on the esc under the TP mode select profile #1
Krazykeith 02-09-2011 10:42 AM
I was tryin to figure out how to get in blinky today and found this thread.....Tried this out and Our stock enduro truck is BLINKING.
STROKD 02-09-2011 02:01 PM
What exactly is accomplished by doing this?
Axo24 02-09-2011 05:35 PM
In some classes that require a "spec" esc...they will allow esc's like the tekins as long as they are in "spec" mode aka "blinky". The speed control blinks to let the tech guys no know its in spec mode. This spec mode allow no esc timing advance,so not to have an advantage over other escs that are legal in "spec" classes. Kind of a waste of an expensive speed control,but at least you dont have to buy another esc if you have a spare tekin like many of us do.
