TX or RX Channel Bleed??!!??!!
Ok, check this out. I bought a FlySky gt2 2.4 w/receiver.
I had to re-bind it but that was flawless. I calibrated my ESC (trx xl-5) and that went fine as well. But this is odd....everything works great until I turn steering hard right...then the doggone THROTTLE starts...without any pressure on the trigger. All of the settings are "neutral". Problem continues with the steering throw expo set at full or none. I unplugged the steering servo completely and the problem continues. That leads me to believe that it is either a transmitter issue or a receiver issue. I ordered a second receiver for another model....so I'll give it a try tomorrow. Has anyone run into a similar issue with transmitter/receiver on a 2.4 Digital system before?? Any help would be appreciated. |
| All times are GMT -7. It is currently 04:16 PM. |
