Using a lipo as a power source
I race Nitro. I want to know is it feasable to use a couple of high capacity Lipos as a power source. Getting tired of carring a lead acid battery as my portable DC power source.
Pass you soon... |
Of course. A battery is a battery, volts are volts.
You have two options: one 4 cell or two 2 cells. Just don't run them down like you would a SLA or poof! You could wire in a voltage cutoff or monitor to keep tabs on the packs and you will need a lipo capable charger. |
I was thinking of paralleling 2 4s @5000mah. That should last me all day. I only have to charge my rec pack(800mah, My glow charger and maybe my transmitter batteries) 10000 mah capacity should handle this with no problem.
I just have to justify the price vs a PB battery thanks for the reply Pass you soon... |
Originally Posted by lil-bump
(Post 8550953)
justify the price? no problem. weight, size.
Well I done some research. With a fully charged 4s lipo (16.8) I believe my Charger (Triton II) would fault on excessive input voltage. The triton is rated between 11- 15 Vdc input. So I may have to look at a 3s lipo. The best price I can find is About $31 dollars with free shipping form China.
To be continued Pass you soon... |
(Post 8550953)
I made a battery box using a 8000mah 4s Li-fe and it works great all day.
Pass you soon... |
| All times are GMT -7. It is currently 09:14 PM. |
