looking for good power source
I have a imax b6 charger and need good ps. Ive using truck battery and that is getten real old. Id like something that could run mult. chargers. any ideals
Thats a 50watt charger and all you really need is a supply with mor ethan about 60watts. Something like this would work -
http://www3.towerhobbies.com/cgi-bin...?&I=LXYGX9&P=7 Check and see if the connection to the charger looks like what you need. If you have a spare laptop power supply lying around and could get it connected, that'd prob work as well. |
yeah but that wont run multiply chargers
If you need a lot of current for multiple chargers, your best (cheapest) bet is to make your own from a PC power supply. Look for something with a single +12V rail with lots of current handling capability like this. Then follow this guide. That'll give you a 25A (300W) 12V power supply for about $20.
Originally Posted by cbass722
(Post 8465184)
http://www.progressiverc.com/index.p...emart&Itemid=1 There are PSs available to well over 1000watts. PS selection really depends on what you're charging and how many chargers you'll be running off the same supply. You can determine the needs of each charger then allow for the chargers inefficiency and get the needed wattage in a PS. |
| All times are GMT -7. It is currently 04:04 AM. |
