Need help!
3 Attachment(s)
Hello there, im new to rc models ive been given a TT-01 to build with a Mtroniks Viper Eco27 ESC.
Its build, and ready to be operational. However it seems to only steer. The acceleration doesnt seem to happen although i know the motor works What have i done wrong? Pics attached. |
Have you calibrated the esc to the transmitter? That has to be done after the wires are all connected. It should be covered in the manual or instructions for the esc.
Originally Posted by Duster_360
(Post 8459662)
Yeah i have i followed all the instructions and esc setup with no success. Motor is fine tried it directly connected to the battery.
I had to email the manufacturer as i dont know what else to do Thanks for the support... |
Sorry its not working, if you're following instructions and its not calibrating, it sounds like the esc is bad.
You can run into probs depending on the radio you're using that won't allow esc to calibrate. Throttle and brake endpoint adj on radios (if so equipped) need to be set 100-120% before trying to calibrate. |
Nevermind with a little help from a friend its all sorted.
Thanks anyway :D |
| All times are GMT -7. It is currently 07:56 AM. |
