dynmite passport problems
I dont know if anybody else has encountered these problems but when my lipos are unbalanced by .040 0r worse i cant balance charge them up, the charger will keep running and running and they get a little worse and worse while my overall voltage stays the same with out increasing. Any help would be nice, thank you.
Assuming there's not some kind of probs with these lipos, charger shouldn't be doing that, balance spec should be balancing cells to within 10mv of each other. Does it happen with all your lipos?
If this is still under warranty, you should check with where you bought it or contact Dynamite. |
No I have two used lipos and then I put a new one on to see what would happen I thought the same thing thinking it was just my lipos.
Contact Dynamite and explain what the charger is doing and see what they say.
http://www.dynamiterc.com/About/Contact.aspx I'd call the support number and see if they can help. You may be unlucky and have a charger thats developed a prob in the balancer. |
| All times are GMT -7. It is currently 02:19 PM. |
