can you bind a spektrum radio/receiver without a bind key?
i just bought a radio/receiver and im having a little trouble binding the two.. i can get the radio into bind mode... but not the receiver... i dont have the bind key so i figured thats what it was.. i have a SR3001 pro series receiver... i dont even see a bind key port on it.. any help would be greatly appreciated!!!
thanks in advance!
thanks in advance!
3001 pro series has a bind button on it that is green. As far as radio what radio do u have?
The bind plug is only a jumper so as long as you jump the same 2 pins (the outside 2 pins) with anything metal you will be doing the same thing as the plug.
If all else fails RTFM.
i read the F'n Manual.. its not as easy as i thought it would be to read (the dx3s)
anywho.. yeah i got that one to work i meant my sr3300t
so if i use a wire to each it would work? any old wire? like speaker wire?
