-   -   2.4 compatible? (https://www.rctech.net/forum/radio-electronics/467926-2-4-compatible.html)
drifterboy3 01-04-2011 08:33 PM
2.4 compatible?
I have a 2 channel traxxas2.4 (not the link) and I was wondering if it is compatible with any other 2 channel rx? Any help info is appreciated thanks:confused:
crusey_aus 01-04-2011 08:50 PM
Traxxas TX works with Traxxas RX
Cheers
drifterboy3 01-04-2011 08:52 PM
So you can't bind a traxxas tx with spectrum rx
crusey_aus 01-05-2011 01:13 AM
Thats correct
Spektrum TX will only work with a Spektrum RX
Cheers
Duster_360 01-05-2011 03:51 PM
Generally, none of them will work together cross brands. They use diff enciding/decoding even though its the same 2.4Ghz. I don't think your Traxxase 2.4 will even work with the newer 2.4 Traxxas link equip.
There are few exceptions - Spectrum made some cheaper rcvrs that were re-badged by someone (Losi I think). But the radio manufacturers are moving to eliminate that option with their newer, low priced radios. The low end 2,4 radios are not compatible with the higher priced ones as far as using rcvrs.
