Charger advise
Old 12-30-2010, 06:18 PM
Default Charger advise
Just bought my son a Slash 4x4 VXL an I'm about to order another one for us to play with together. I'm also gonna order 5 11.1V 5000Mah lipo batteries aswell but I'm really confused as to what charger to get. The main 2 I've been looking at the Team Checkpoint TC-1030, Triton2 an then the Triton EQ as 3rd choice. My thoughts was I wanted a charger with temp prob an balancer which would be the TC1030 or the Triton2 since the EQ dosent have the temp probe ability. Is the temp probe very important? Any advise would be much appreciated
rip1976 is offline
Old 12-30-2010, 07:26 PM
reptile's Avatar
Trader Rating: 138 (100%+)
I would get a icharger 206B+ or a cellpro 10s they have up to 10 amp charge but you will also need a power supply
reptile is offline
Old 12-30-2010, 09:03 PM
Trader Rating: 21 (100%+)
As you stated, what you should look at is a lipo capable charger with a builtin balancer and enough charger output power that it will deliver a full 1C charge (1C charge = lipo capacity/1000, so for a 5000, 1C = 5000/1000 = 5amps). The TC1030 (have one, but use only for NiMhs) lacks a balancer so you'd need an external charge thru balancer which can be a pain to get wired correctly
The Triton EQ is just a 50watt charger, it will limit charging current to stay under its 50watt power output limit and it will require longer charging times due to this reduction, but it has a builtin balancer (equalizer as they call it). The Triton 2 is 90watts and wouldn't experience this charge limiting but will once again need a separate balancer. Since these are all DC powered and you either have a power supply or realize you'll need one, consider an iCharger 106b+, its 10amps max charge rate and has builtin balancer and can use a temp probe. Its a 250watt charger and with a sufficient power supply you could charge those lipos at 2C (10amps) if the lipos are 2C charge capable and shorten charge times.
http://www.progressiverc.com/index.p...emart&Itemid=1
Temp probe is pretty useless/unecessary when charging lipos, I charge some of my lipos at 15amps and temp may rise 2F above room temp. I don't bother connecting one any more.
Duster_360 is offline
Old 12-30-2010, 09:53 PM
simplechamp's Avatar
Trader Rating: 73 (100%+)
I give another vote to the iCharger 106B+ or any one in the iCharger line. They are great and I wouldn't hesistate to buy one again. Also, David at Progressive RC is a great guy, fast to answer questions and very helpful.
simplechamp is offline
