-   -   lipo receiver pack (https://www.rctech.net/forum/radio-electronics/465214-lipo-receiver-pack.html)
pro306 12-27-2010 05:13 PM
lipo receiver pack
has anyone ran a 2s lipo receiver pack. if so did you have any problem with the servos. most servos are rated at 6v. i'm thinkn about using a receiver pack to power my receiver and servo and use the internal bec to power the esc only. i'm tryin to fix my glitch problem with mmp and balistic 550 combo.
Eddie
TOM MAR 12-27-2010 06:15 PM
Attachment 685092
If you are not using a digital servo this works good. instructions are on the back. it's only 1 amp but gives you 5 volts output with up to 30 volts imput. about $1.50
pro306 12-27-2010 07:24 PM
thats cool good info. my only problem is i have digital servos. but ill keep it in mind for the future.
TOM MAR 12-27-2010 08:51 PM
It may work, I haven't tried it. I'm fairly sure digital pulls about 1.25 amps, just a guess.
I think I can put two in parallel, that would be good for 2 amps & that would be plenty. If I go digital I'll try it & respond my findings.
Failedabortion 12-28-2010 09:20 AM
I had to run a rx cap to solve my glitching problem with the mmp/550. A castle bec would also be another option and something I would use instead of a rx lipo.
