-   -   Mamba Max Pro SC? (https://www.rctech.net/forum/radio-electronics/465117-mamba-max-pro-sc.html)
meon99 12-27-2010 11:17 AM
Mamba Max Pro SC?
how well is the Mamba Max Pro SC esc and the 2400 motor? are there any differences compare with the max pro normal version? Thanks.
crusey_aus 12-27-2010 01:42 PM
ESC is the same as far as I know, just a nice label
Motor should be a ripper
Cheers
Duster_360 12-27-2010 06:06 PM
Says this combo is 4S rated, not 6S like teh MMP is. This may be application sepcific like the HPI 2350 Flux - that is an MMP also thats only 4S rated.
http://www3.towerhobbies.com/cgi-bin...?&I=LNAETU&P=G
crusey_aus 12-27-2010 06:18 PM
Castle being conservative by rating the Motor for 4s (6s would be 60,000 rpms)
They havent added it to Castle Link yet so I guess we'll have to wait and see
The HPI ESC is limited by software guess they could do the same
They are charging similar price to the MMP would be surprised if they hobbled it
Cheers
crusey_aus 12-28-2010 12:17 PM
Confirmed by Castle the ESC will be 6s capable
Cheers
simplechamp 12-28-2010 12:43 PM
They rate the combos at 4S (and the HPI RTR setup) so people who don't know any better don't try to run 6S and fry their gear when using an inappropriate motor. The MMP SC and HPI branded Q-Base are still both a regular MMP rated to 6S.
meon99 12-29-2010 11:12 AM
anyone had experience with this combo?
meon99 01-20-2011 11:33 AM
any updates?:nod:
PUNMAXXRCFX 02-24-2011 08:18 AM
The SCT version and the regular version are exactly the same except for the sticker color , the 2 ESC are capable of going up to 6s but if you are using the 2400kv 1415 motor you must used either 3s or 4s and nothing else on the MMP or MMP SCT ESC .
RAPER 02-24-2011 08:58 AM
Not true. You can run 2-4s with that motor. The ESC is the same as the standard MMP. I have this combo and I am patiently awaiting my ten-scte to put this into.
crusey_aus 02-24-2011 12:38 PM
I'm running the combo in my Slash 4x4, motor is a ripper
Geared for 65mph on 4s it bursts to a lazy 2300 watts (170 amps or so)
Motor is actually rated for 5s / 75,000 rpms according to the label that is on it
Wouldnt be running 5s in a SC truck unless it was just for some speed runs
Castle's gearing reccomendation for a Slash 4x4 is fairly conservative at 40mph (4s lipo)
Here is their chart for various cars
http://www.castlecreations.com/suppo...ring_chart.pdf
Cheers
