Spektrum receivers?
So I'm getting back into racing and I've decided to jump into the 21st century and get a 2.4 radio. I've decided to go with the Airtronics M11 on Spektrum. I chose the M11 because I used Airtronics when I first started racing in the late 80's with great succss. I chose Spektrum because the rx's seem to be plentiful and well priced.
Here's my question. About Spektrum receivers: which ones will work with the M11 module? Will the Losi receivers work? What is the best receiver for the money? Thanks! |
Any spektrum surface rx that is dsm should work, dsm2 will not work.
These should work with the m11 spektrum module. sr300 sr3000 sr3001 sr3500 The losi dsm rx's will work also, I believe they are the same as the sr300 rx. |
Originally Posted by Failedabortion
(Post 8385080)
Ok.
Still figuring this out. What is the difference in dsm and dsm2? |
Originally Posted by jag5508
(Post 8385332)
And if you run the airtronics spektrum that comes with the M11 fhss 2 or dss you have to run their receivers .
DSM2 has a faster response time. The SR3001 and SR3500 also have faster response times than the other DSM RX's, but are not as fast as the DSM2. But to take advantage of them, you have to have a pro module. You will be able to use just about any Spektrum brand RX except for the SR3520 and the SR3100.
Originally Posted by Left Front Tire
(Post 8385530)
Am I understanding correctly: if you use the Airtronics module you have to use Airtronics recievers, and if you use the Spektrum module you have to use Spektrum recievers?
so do they make a spektrum pro module and a non-pro module?
or does the pro module work with the regular rx's like the s300, sr3000, losi, etc, etc? |
Hey all, I ran into some trouble recently with a lock-out as a result of range problems with my AR6100 and totalled my plane. No big deal, gots to keep the spirits up and repair by next weekend for flying! But I did do a lot of research that established by consensus that the AR6100 is a medium-ranged receiver. Spektrum/Horizon Hobbies does not state a range for their receivers but instead use vocabulary such as "Park" or "Reliable" or "Full Range" to describe their line of 2.4ghz receivers.
Originally Posted by gotspeed24
(Post 8394132)
thanks pakk.....so the pro module doesnt work w/ dsm2 receivers? hmmm wonder why.....my older dx3s works fine w/ dsm2 recievers and its only dsm. suprised the pro module wouldnt work with the dsm2 rx's:confused:
The DX3S will work with DSM2 and DSM but the modules don't. Both the non-Pro and Pro modules can be used with Pro and non-pro receivers.
| All times are GMT -7. It is currently 10:08 AM. |
