3s li po off balance advice???
I have a thunder power 3s hard case and the 2 cells balance at 4.20 and the off cell only stays at roughly 3.8 is this repairable discharging and charging or is the battery now garbage? i got it from a member and have only used it twice now. any advise would be greatly appreciated.
Merry Christmas
Merry Christmas
Is the charger timing out on you while trying to balance out this diff? Balance spec is <10mv so it should be getting closer than 3.8 to 4.2v, that's 400mv.
I'm trying to understand why the chargers not doing a better job.
You'd have to rig up something sepcial to charge just one cell and its prob not worth all that it would require.
Fix for out of balance packs
The answer is almost always the same for out of balance packs:
Balance the pack and test.
