-   -   What type of plug is this? (https://www.rctech.net/forum/radio-electronics/462766-what-type-plug.html)
HyperTT 12-18-2010 01:35 PM
1 Attachment(s)
Hello all,
I'm trying to use the power supply that came with my old Duratrax IntelliPeak Digital Pulse Charger for my new Turnigy Max80W charger.
The problem I'm having is so far I've been unable to disassemble the old lead connectors. I've also been unable to identify them so as to purchase new ones. I've included a picture any help would be appreciated.
Thanks - Derrick
Duster_360 12-18-2010 02:36 PM
Looks like a Tamiya male which is sometimes called a 'standard' connector. The puzzling thing is the clip on the side, I've never seen one on the side like that. This one is typical, clip is in the middle.
http://www3.towerhobbies.com/cgi-bin...&I=LXNGB6&P=ML
They're not the greatest connector, tend to get sof t and melt at high current. I'd replace it with something more convienent to use.
HyperTT 12-18-2010 02:56 PM
I've got some Tamiya males, this is smaller and like you noted the clip is on the side. Also the half circle point in towards the square instead of down.
I would change the plug if I could but it plugs directly into the power supply. Also it shouldn't be too important it only needs to support 7 amps for the charger.
stinger30 12-18-2010 02:57 PM
the clip on the side is a "lock" clip
when both plugs are put together the "lock" click you see in this photo will "lock" to the other side of the plug so it doesn't get ripped apart easily
Duster_360 12-18-2010 04:28 PM
Its not a mini Tamiya either - I have those on plane batteries and that has a full circle and a square connector guide, latch or clip is in the middle like standard tamiya.
You might email DTX and ask them what that is and where you might find one.
simplechamp 12-18-2010 06:37 PM
I'd ditch that connector (don't worry about taking it apart, cut it right off) and go with something like 4mm banana plugs or Dean's Ultra T-plugs.
HyperTT 12-18-2010 06:48 PM
Thanks for the idea, e-mail sent.
I'm not looking to use it to charge the battery, I'm looking to use it to plug the charger into the power supply. That plug will never go on my car, but if I could locate a new one it would help in plugging my charger into the wall.
simplechamp 12-18-2010 07:15 PM
Right, I know it's for connecting the PSU to the charger. I just think it would be probably just easier to switch to a more common and available plug than search all over to find a match for the one on there, given that it is subpar compared to other plugs available anyway.
HyperTT 12-18-2010 07:19 PM
Only problem is the PSU doesn't have wires coming out of it, just an opening where you insert that plug.
simplechamp 12-18-2010 10:28 PM
Oohhhhh.... OK, I thought there were wires coming out of PSU with that plug on the end. Now I see why you need to match it. Should have read a bit closer in your other post!
skree 12-20-2010 02:46 AM
You could always try taking the PSU apart and putting a cable on the back of that socket, then put any plug you want on it.. even one that plugs directly into the turnigy
HyperTT 12-20-2010 09:46 AM
Well Duratrax replied to my e-mail, they claim it's called a standard connector and online stores and LHS' should carry them. :confused: I don't know if mine's older then most and they changed their product somewhere along the line or if they were confused by me e-mail and thought I was talking about the outputs?
racer1812 12-20-2010 10:01 AM
They must be confused, the "standard" tamiya connector has been around for something like 30 years and what you have isn't it.
Duster_360 12-20-2010 10:02 AM
Since you're emailing, reply back to them and maybe include the pic and point out it is not the standard connector and why. If you can't find out, your options are dwindling.
HyperTT 12-20-2010 10:16 AM
Yeah it seems that way, Mouser sells thousands of these things but they don't all have pictures and without a p/n it's pretty hard to navigate their web page.
