Will a Spektrum DM8 Air module work with a 3PKS?
Like the title says...Will a Spektrum DM8 Air Module work with a Futaba 3PKS?
I have tried a Corona module and it works OK, but for some reason the receiver doesn't stay bound. I assume that the Spektrum module should work and bind with Spektrum air receivers also. Obviously I won't get more than three channels. One worry I have is that there may be some odd bit that won't allow the DM8 to work with the 3PKS...or worse, fry my module or the 3PK! Kind of afraid to turn the power on to try it.
The module fits and snaps in OK, however it is too tall to allow the cover to snap in.
Another part of my question is: Will the DM8 module bind with Spektrum SR300 or SR3000 receivers? Do the air and land products follow some different protocalls which will not allow them to work with each other?
Thanks for the reply...
I did end up trying it out, and as you said the SR300 and SR3000 would not bind with the module. I didn't try the air receiver with it because I only wanted to know if the surface receivers I had would bind.
It was worth a shot anyway...
